Lightflyer1
For those of us dumb as rocks on this stuff, what exactly is happening here? A new pump? What car is this in?
This is the cp4.2 pump in a 2010 JSW.For those of us dumb as rocks on this stuff, what exactly is happening here? A new pump? What car is this in?
Is the plan to offer this pump with a retro fit kit sometime in the future??This is the cp4.2 pump in a 2010 JSW.
Yes once we get the components fitment perfected it will be a bolt-on plug-n-play upgrade.Is the plan to offer this pump with a retro fit kit sometime in the future??
Very cool! I believe you will sell a lot of themYes once we get the components figment perfected it will be a Bolton plug-n-play upgrade.
Same engine.3.0 touareg must be the same as the Audi one.
Ill take your $100 dollar bet. Ill PM you my paypal so you can just send me your money now.How does the rail act "as a pressure accumulator of sorts"? Does it have something that compresses inside of it? Fluid is not compressible and I do not see the rail itself having anywhere near enough "elasticity" to accumulate pressure at all.
I bet if you timed the oem pump the opposite way, the motor would not run at all. I could be wrong, but I'd bet $100 on that. Lol
It works the same way a hydraulic circuit works on trucks. The pump produces flow, a restriction in the flow produces pressure. Pressure is controlled by PWM from the PCM through a solenoid.I would guess that somewhere, there is a compression element, seeing as Bosch does refer to the fuel rails in common rail diesel systems as pressure accumulators...
