Old June 3rd, 2013, 21:03   #1
boertje
boertje's Avatar
Default Swapping ECU from a 2003 bug or 2002 jetta into a late 2001 bug TDI
I might have to replace the ECU in my 2001 bug (038906012CR). Hopefully Malone can recover it. Was wondering what my options were and what I would have to do in terms of programming? My 02 jetta is a EDC15VM+ with part number 038906012FD and my 03 bug is a EDC15VM+ with part number 038906012GQ.
Can these be used? What is involved?
'01 and a 2nd '01 and a '03 NB TDI with 6 spd manual. '06 NB GLS TDI DSG.
All with Malone tuning of course.
Auto to 5/6 spd manual swap with wiring instructions for MKIV. Click here.
boertje is offline   Reply With Quote
Old June 3rd, 2013, 21:49   #2
Seatman
Seatman's Avatar
Fuel Economy: No idea
One thing I think could be the immo, the 02 and 03 are immo 3 but the other is immo 2 and I'm not sure if the ecu is backwards compatible or not.
Seatman is offline   Reply With Quote
Old June 4th, 2013, 23:04   #3
boertje
boertje's Avatar
Malone says it might work. I think I would have to do an immo delete to use a new ECU. I'm surprised nobody has a concrete answer for this.
Seatman thanks for your input!
Old June 4th, 2013, 23:10   #4
Arctic Jetta
Fuel Economy: Best seen, 54 MPG
I've always been told the only stupid question is the one not asked, so here's my stupid question. Where is the ECU located on a 2002 Jetta TDi ALH? Thanks.
Arctic Jetta is offline   Reply With Quote
Old June 5th, 2013, 13:20   #5
jack1
Fuel Economy: allroad 47mpg, a4 avant 55mpg, t25 (t3, vanagon)35mpg
as Malone states it will work with immo delete once the engine types are the same
jack1 is offline   Reply With Quote
Old June 5th, 2013, 13:30   #6
davebugs
Inside - under all the dash plastic by the windshield.
I have an ECU form a 99 ALH 5 speed NB for sale if that'll help you out - no immob I believe.
davebugs is offline   Reply With Quote
Old June 5th, 2013, 13:52   #7
Seatman
Seatman's Avatar
Don't the early ones have different plugs? I'm pretty sure I read that on here somewhere.
Here I did a little write up on that one
http://uk-mkivs.net/forums/p/494434/...3.aspx#3400743
Old June 5th, 2013, 14:01   #8
davebugs
Oops - since the thread was about a NB that's how I answered - it's inside on a Beetle.
Under rain tray on Jetta and Golf.
Old June 5th, 2013, 14:13   #9
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
The concrete answer is you need an ECU with same part number.
The fact that a reputable chip tuner thinks it might work means he probably knows what minor mods to do, worth checking out.
Car-Part.com has used ECUs at reasonable prices
Old June 5th, 2013, 21:12   #10
Arctic Jetta
Seatman-thanks for write up post! That really helps! Thanks for the replies.
Old June 6th, 2013, 08:19   #11
boertje
boertje's Avatar
True, they do indeed have a different plug.
Do keep in mind that for US cars everything that Seatman shows is on the opposite side from ours since his car is right hand drive.
Seatman, BTW, great write up.
Yes, Malone told me that the part number needed to end with 012 XX where XX could be any letter(s) and that then it MIGHT work.
I checked out car-parts and there is a ton of them out there ranging from $25 to $350. The good news is that malone was able to recover my ECU and flash it with the tune I was trying to flash into it to begin with so looks like I'm good to go.
FS: ECU 038 906 012 GQ with Immo off, 2003 BUG jetta ,97 Private TDI Items for Sale/Wanted 3 February 3rd, 2012 02:14
FS: ECU Immo delete, 038 906 012 CR 2001 Bug jetta ,97 Private TDI Items for Sale/Wanted 5 November 17th, 2011 08:58
00 bug tdi ecu VWDAVID Private TDI Items for Sale/Wanted 6 September 16th, 2011 18:34
2001 TDI Bug in Wichita, KS JHoffman TDI Cars for Sale/Wanted 14 November 16th, 2010 10:29
2003 TDI Bug part out dubjnke Vendor & GroupBuy items for sale 23 May 21st, 2009 20:08
Page generated in 0.15149 seconds with 11 queries
[Output: 106.17 Kb. compressed to 90.34 Kb. by saving 15.82 Kb. (14.90%)]
