Go Back   TDIClub Forums > Classifieds/For Sale/Wanted > Private TDI Items for Sale/Wanted
Private TDI Items for Sale/Wanted VW TDI/Diesel related items for wanted and for sale by private individuals. Group Buys and commercial posts should be in the "Vendor & GroupBuy" section.
Old November 1st, 2011, 21:12   #1
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
Default FS: ECU Immo delete, 038 906 012 CR 2001 Bug
SOLD.
I have ECU that has Immobilizer delete. This ECU is plug and play , no adaptation needed. It was in 2001 Beetle.
Part number 038 906 012 CR .
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK6 Needle Sweep,MK5 with MK6 Cluster
jetta ,97 is offline   Reply With Quote
Old November 8th, 2011, 18:15   #2
jetta ,97
jetta ,97's Avatar
This is a perfect solution if you want to tune your car with EGR delete,you can have this ECU as a spare if you have emission check to pass it easy.
HEX+CAN
Old November 9th, 2011, 19:02   #3
jetta ,97
jetta ,97's Avatar
Bump...
HEX+CAN
Old November 15th, 2011, 07:16   #4
jetta ,97
jetta ,97's Avatar
Bump...
HEX+CAN
Old November 16th, 2011, 15:54   #5
amosdoodle
Hi, I am interested do you do pay pal?
Tom
amosdoodle is offline   Reply With Quote
Old November 17th, 2011, 08:58   #6
jetta ,97
jetta ,97's Avatar
Yes , PM sent.
HEX+CAN
FS: Immo 2 ECU 038 906 012 CP: Immobilizer DELETE jetta ,97 Private TDI Items for Sale/Wanted 13 May 2nd, 2011 10:45
FS: Immo 2 ECU 038 906 012 CP with Immo off jetta ,97 Private TDI Items for Sale/Wanted 1 April 3rd, 2011 17:59
FS or FT 19 psi tune chipped ECU 038 906 012 GN with immo delete tothemax Private TDI Items for Sale/Wanted 2 April 11th, 2010 18:40
Fs Ecu: A4 Immo 3 038 906 012 Gn mackwood Private TDI Items for Sale/Wanted 1 November 13th, 2006 08:07
ECU- Immo 3 PN# 038 906 012 GN***SOLD*** mackwood Private TDI Items for Sale/Wanted 6 July 11th, 2005 12:03
Page generated in 0.13067 seconds with 11 queries
[Output: 78.32 Kb. compressed to 68.46 Kb. by saving 9.86 Kb. (12.59%)]
