Old October 11th, 2010, 16:09   #1
raffshore
Default Stand alone controller for CR engines?
I have no connections to the company !!!
I was browsing the net, when I found this :
http://www.bodylogicuk.com/90265/info.php?p=10
http://www.youtube.com/watch?v=CvvEJ1sgTqU
raffshore is offline   Reply With Quote
Old October 11th, 2010, 16:18   #2
Bush Hopper
Bush Hopper's Avatar
Someone check the price? So far Bosch was the only option. Nice to see some alternatives.
Real airplanes don't have spark plugs.
Best line ATC ever made "Land at your discretion on the 407"
Bush Hopper is offline   Reply With Quote
Old October 11th, 2010, 18:47   #3
Woody 35
TDI(s): 2005 Passat
Fuel Economy: 42 MPG
in the video it said 3000 euros
2005 Passat TDI GLX steel glowplugs
1997 Chevy K1500 6.5 Turbodiesel
Woody 35 is offline   Reply With Quote
Old October 11th, 2010, 19:25   #4
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
wow.. I'm sure you could bribe Jeff to tune one if you have the harness and ECU out of the car the engine came from.. He's advertising CR tuning on his website now so I see no reason why he wouldn't tune one of you do a swap of some sort..
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old October 11th, 2010, 20:38   #5
hatemi
There are actually few other options aswell. Nira being one of them.
www.tdituning.fi
hatemi is offline   Reply With Quote
Old October 11th, 2010, 23:54   #6
Rub87
the other french ecu seemed also promising, the website said it was ready for sequnetial turbo control etc
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old October 12th, 2010, 00:37   #7
keaton
keaton's Avatar
TDI(s): 2005 Mk5
would be nice to know number of maps, maps sizes, rev limits.
i see 3 aux outputs so i wonder if one of them can do PWM & CAN for electronic VGT/VNTs. wonder if there are user defined map for general purpose
so who here is gonna be the guinea pig and retro fit this ECU to a IP TDI.....
keaton is offline   Reply With Quote
Old October 12th, 2010, 06:36   #8
TDIJetta99
TDIJetta99's Avatar
someone send me one and I'll gladly set it up on my build.
Page generated in 0.13999 seconds with 10 queries
[Output: 81.30 Kb. compressed to 69.34 Kb. by saving 11.96 Kb. (14.71%)]
