Car is new to me, one previous owner, southern US state driven 2001 late production (10/00) Jetta ALH 5-speed with 194k (presumably mostly highway/freeway) miles currently. It is in very good condition overall for age and mileage. As far as I know the car is stock, with no modifications.
Issue with the car is that when it hasn't been run recently it takes a long time to get started, like 3-8 seconds of cranking, and that's with the ECT sensor disconnected. If the ECT sensor is connected, it can get started, but it takes a very long time, like 10-30 seconds of cranking, and quite a bit more smoke when it finally starts.
In March 2010 the previous owner took the car in for service. His issues were timing belt service was due, car is hard to start/having to pull ECT, and losing diesel fuel on the ground. The shop did timing belt service (including water pump) that was due, and replaced the fuel injector pump and fuel filter due to old pump leaking, and replaced a broken oil dip stick tube. I purchased the car 2 months and 2k miles later. Obviously the start issue wasn’t resolved.
If the car has been run recently (even if not all the way up to normal ~90c operating temperature) the engine will still start much more quickly; Less than 1 second to 3 seconds of cranking if ECT is disconnected, and 1-6 seconds (?) if ECT is connected.
I haven't tested extensively to determine after what time frame it no longer starts up quicker, but I do know the effect lasts for a while, like an hour or two at least, and the engine starts better the more recently the engine was last run. So I’m thinking issue is possibly either engine temperature related, or something to do with some fluids getting moved around that stick around for a while enabling an easier start, or some sensor reading being correct after the engine just ran, but these are just blind conjecture at this point.
Once started, with ECT either connected or disconnected the car runs and drives fine, no idle issues, no power issues, no smoke issues, etc.
I've been through the TDI FAQ slow start troubleshooting page, and a couple of forum posts and at this point could use a pointer in the right direction...
Here's what I've checked and done so far:
Replaced ECT - ECT was disconnected by previous owner to start car easier, and was likely also bad (dash gauge was non-working even after I plugged the connector on again). I replaced with new ECT sensor, dash gauge now works, and VAG-COM readings look good, both ambient and at running temperature.
Replaced engine air filter – Old one was dirty, replaced with new Mann filter.
From the TDI FAQ page section on ‘engine is difficult to start, requires a long period of cranking before starting’:
Weak battery - Old one was pretty good, replaced with new OEM sized one anyway due to upcoming winter.
Corroded electrical connections - Battery terminals look very good, I haven't checked ground straps, but starter cranks nicely at 250-300rpm, and car starts quickly when recently run, so I don't think this is an issue.
Air in fuel system – Replaced fuel filter, checked and replaced the o-rings on T fitting, vacuum pulled fuel through injection pump, loosened injector fittings and verified fuel was running through them before tightening. Clear tube shows 1/2" to 1" bubble when engine off, but I have read on forum that this is normal. No bubble(s) visible while engine running. Checked and tightened all connections. I see no leaks on either supply or pressure side.
Fuel filter clogged or filled with water - Fuel filter was 6 months and 2k miles old, replaced with new VW filter as troubleshooting step anyway.
Incorrect fuel injection timing - Checked with VAG-COM, timing was advanced out of envelope after timing belt service with rough ~800rpm idle speed (ran fine, just a lot of vibration, like a large displacement two cylinder motorcycle engine). I adjusted the timing to be midway between the middle and upper line (at just under the top line the idle was still a bit rough) of VAG-COM timing graph. Idle is now smoother at ~900rpm, and the engine now has power to 3500rpm instead of 3000rpm. No difference in starting.
Anti-shudder valve problems - Checked that valve moves freely and is spring loaded to be in open position.
Poor quality fuel - I have only filled up twice at the same name brand station, but the previous owner had the same issue multiple states away, so not likely.
Cold temperature - Not an issue, ambient temp has been between 60-90F (16-33C), VAG-COM reports normal fuel temperature.
I've checked the codes with VAG-COM, there were a few in there that I saved to log and then cleared when I first hooked it up. There is an ECT sensor intermittent short code that comes up when I disconnect the ECT. If I leave the ECT connected and drive/use the car with it connected I do not believe I have seen it come up. No other codes, other than one for my remote key fob.
I've checked the other group measurements I thought/knew to look at and I believe all measurements were within spec, but can check anything again and provide measurements/screenshots/logs if desired.
Coolant and oil levels are good. The only thing I haven’t done yet that I was going to anyway due to it being a new to me used car is to change the oil and oil filter.
I’m now to the point where I do not know enough about the car to be able to continue intelligently troubleshooting. Help appreciated!
