M
mickey
Guest
I stuck a new oil filter in Katie on Saturday. (Katie is a car, by the way.
) I was very impressed by Mercedes Benz's design. I'd been told that MB provided a factory bypass filter on the diesel engine, but I couldn't find it. When I changed the one I COULD find, though, I realized that they cleverly made a combination full-flow/bypass filter in one cartridge!
The filter is a simply cylindrical unit, similar to an A4 TDIs filter. Approximately the bottom 1/3 is just a pleated paper full-flow element. But the rest of the filter is covered with sheet metal, with dozens of very small holes poked in it. Through the holes I could see densely packed fiberglass (or cotton, or something) filter material. Apparently the upper part of the filter is the bypass part! The two parts are separated by two o-rings on the center "stalk" attached to the filter housing cover. And the really cool part is that the filter elements are dirt cheap!
Hurray for Mercedes Benz! Every time I tinker with the car I notice some other simple yet effective engineering marvel. (Like the engine oil cooler integrated into the radiator. Or the big alloy cooling fins on the differential cover. Etc, etc...)
-mickey
-mickey
