bobmutch
>>>7. LRR tires -- 4x100 to 5x100 Hub Kit and put honda insight 165/65/R14 tires and rims on my mk4. they gave the honda insight additional 5mpg. they are rated very high for LRR and the 165 width is nice. Issues are Hub Kit, front caliber clearance, difference the small tire will make on FE?
I learned a lot about hyper mileing on my Honda Insight. I pull one level no windly trip of 30km and got 104.8mpg-us. Of course I surge and glided in 4th at 20mph to 45mpg until I used the battery up and then keep it in lean burn for the rest of the way.
I like the 165mm width of the Honda Insight OEM Tires and I read lots of testimonies in the insight forum on the difference between those tires and any others. So I have a few questions.
1. Is there a way to deal with the clearance of the front brake calibres there looks like there is a 1/4" clearance. Can these be changed out.
2. Dropping down to a 14" tire -- will this effect mileage due to not traveling as far.
3. How would I fix the speedometer so it reads right.
Bridgestone Potenza RE92 P165/65R14 78S
Tubeless Steel Belted Radial M+S
Treadwear 260 Traction A Temperature B
Made in Japan
This is #7 in a list of 20 things I am looking at doing to my 2000 Golf TDI to try to get it over 83.4mpg-us.
http://forums.tdiclub.com/showpost.php?p=3851830&postcount=2
Made in Japan
