xsp2467
- Joined
- Mar 28, 2010
- Location
- Cordelia
- TDI
- 81' TDi Caddy, 98' Jetta (Organ Donor), 92 Montanna Green GTI (Future TDi swap victim)
Its been a long time coming but I'm going to post my Caddy Tdi swap. I spent a long while looking at other swaps and deciding which direction I wanted to do with mine. I decided that it will have a complete CE2 conversion out of necessity. I wanted to do something about the horrid **** box conversions that people do to their Mk1's so I decided to cut the floor and put a partial MK4 exhaust tunnel in to house a newer style shift box. I also decided to use an 02J Transmission with a taller .658 fifth gear. The reason for this is I plan on lifting my truck and running 195-75-r14 BFG All-Terrian TAKO tires. I used a late Cabriolet Pedal Bracket Modified so I could use a MK4 DBW. As far as the engine mods are concerned, I decided to use a tune from Mike at TDtuning. The tune is based off an AFN coding with a EGR and Mass Air Flow delete. I decided to go with a VNT-15 Turbo because it was cheap and Titan .205 Nozzles. The inter-cooler is still up in the air, but I purchased a Callaway inter-cooler which has yet to be installed. Im sure im forgetting stuff but please feel free to comment and ask questions so I can explain some of the goodies.
Also the down pipe was made by frankenbuilt and engine mounts are WRD with a mechanical clutch cable conversion. I went with this because I have not found a way I like to do the hydraulic conversion.
Picture time....
Picture time....
