MyAvocation
A brass tap and rubber hose will not crack. My thinking is the ideal time to drain is after running the car -- like returning home. a warm engine bay will thaw any liquid in the hose. And draining the hose, say once a week, should be enough to keep accumulation out of the danger zone.I thought about doing a drain, but feared it could freeze up and crack as well. Plus, I don't want to have to have my daily start up proceedure to include getting on the ground, opening a drain, start the car, blow it out, get on the ground, close the drain, brush off, THEN I can drive!
Obviously the TSB kit is superior... just not cheap and much more labor involved. Can't confirm this is the same kit, but at $800 the drain tube is looking better and better: OEM p/n: 1K0-198-803-B
