JSWTDI09
My 2009 JSW has a steering wheel controller part number 1K0 953 549 CQ. Does anybody know whether or not this controller supports a Multi-function Steering wheel? I have a MFSW but I can't test it until my new harness arrives, so I thought I'd ask just in case somebody else has already attempted to use this combination.
In case anybody cares - an auto-scan of my car is posted below.
TIA
Don
Sunday,13,December,2009,14:04:53:49225
VCDS Version: Release 908.1
Data version: 20091018
Chassis Type: 1K0
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 4F 52 56 62 65 72
VIN: 3VWTL81KX9M31xxxx Mileage: 18480km/11482miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CBE) Labels: None
Part No SW: 03L 997 016 N HW: 03L 906 022 J
Component: R4 2,0L EDC G000SG 5109
Revision: 12H01--- Serial number: VWX7Z0HD248158
Coding: 0050072
Shop #: WSC 00066 000 00000
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 113B600D492300FC880F06E6921900423000
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
Component: Climatic PQ35 142 1212
Revision: 00142032 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000001152550
Coding: 14898F2340041500070000001C000000000873075C000120000000000000
Part No: 1K1 955 119 E
Component: Wischer 181208 021 0501
Coding: 00038805
Shop #: WSC 00066
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0493760
Coding: 0000100
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AC HW: 1K0 909 605 AC
Component: 0L AIRBAG VW8R 038 8600
Revision: 07038600 Serial number: 003E7M080BYD
Coding: 0012364
Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 053 0111
Coding: 0000034
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 974 N HW: 1K0 920 974 N
Component: KOMBIINSTRUMENT 3HL 2418
Revision: V0003000 Serial number: VWX7Z0HD248158
Coding: 0007203
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 T HW: 1K0 907 951
Component: J533 Gateway H06 0071
Revision: H06 01 Serial number: 201008F2001961
Coding: E9807F07001303002002
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T4MHP03
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO 3HL 2418
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000659889119
Coding: 0001205
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 139007885283083F2904058FB0880F0488DC00
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 4F: Centr. Electr. II (J533) Labels: 1K0-907-532.lbl
Part No SW: 1K0 907 532 HW: 1K0 907 951
Coding: 050B0500
Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J245EE16SKB10 H01 0180
Component: J394EE16SKB10 H01 0180
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 08103015155502
Coding: 0001204
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7H2262766
Coding: 0040401
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003684600
Coding: 0001168
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0450
Coding: 0100101
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003658139
Coding: 0001168
End ---------------------------------------------------------------------
TIA
Don
Chassis Type: 1K0
Coding: 0050072
Revision: 00H35001
Coding: 00038805
Shop #: WSC 00066
Coding: 0000100
Coding: 0012364
Coding: 0000034
Coding: 0007203
Coding: 0001205
Revision: 00H15000
Coding: 050B0500
Coding: 0001204
Coding: 0040401
Coding: 0001168
Component: RDK 0450
Coding: 0100101
Coding: 0001168
