Old October 11th, 2017, 10:52   #1
nissansentra
Default Brad penn GL4 Gear OIL
Hey Guys,
I wanted some advice. I am going to change my st-lube gear oil to something not so thick because I have trouble shifting in the winter. Does anyone know of a cheap GL4 oil for a 2004 vw tdi manual transmission? I found this one looks pretty cheap but am not sure if anyone has any good experience with it?
https://autoplicity.com/11170417-bra...xoCVZ8QAvD_BwE
Jordan
nissansentra is offline   Reply With Quote
Old October 12th, 2017, 11:05   #2
3turboz
3turboz's Avatar
Fuel Economy: 37/42/48
See the thread in this sub-forum on synchormesh gear oil.
I just switched over to valvoline synchromesh and it was just under $9 per quart.
Carl - GOLF TDI, 280Z Turbo
3turboz is offline   Reply With Quote
Old October 12th, 2017, 14:24   #3
MichaelB
Fuel Economy: very good
Originally Posted by nissansentra View Post
Hey Guys,
Jordan
Why is cheap so important? quality and stability should come first.
MichaelB is offline   Reply With Quote
Old October 12th, 2017, 15:22   #4
Ol'Rattler
Ol'Rattler's Avatar
Hey, everyone knows that transmissions are cheaper than gear oil. The OP could probably get used fry grease for free.
-OR-
The OP could get the right stuff and skip the science experiment of trying one sub standard product after another: https://www.idparts.com/oem-070-manu...id-p-1438.html
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Seinfeld mechanic clip with Brad Garrett bayshorecs TDI 101 5 December 30th, 2009 08:28
GL5 or GL4? heaveninbc Fuels & Lubricants 7 March 12th, 2008 16:36
Brad's TDI 1, Brad 0 Bradtholomew Ontario 22 February 7th, 2008 10:26
Brad's Fault Code Bootre Atlantic Canada 12 September 2nd, 2005 14:35
Dealer says that GL4 wrong oil for the Transaxel in_shelby Fuels & Lubricants 4 October 9th, 2002 16:30
Page generated in 0.13074 seconds with 13 queries
[Output: 65.29 Kb. compressed to 58.45 Kb. by saving 6.85 Kb. (10.49%)]
