Go Back   TDIClub Forums > VW TDI Discussion Areas > OBD Scanners
OBD Scanners Discussions on using On Board Diagnostic (OBD) scanners/ Diagnostic Equipment related to TDIs
Old July 17th, 2017, 12:24   #1
Beardog1906
TDI(s): Gt tdi sport
Default Bought an obd code reader having trouble resetting the faulty air bag light
Hi guys.as the title suggests I'm having trouble resetting the airbag code with the reader I bought.any advise please.
Beardog1906 is offline   Reply With Quote
Old July 17th, 2017, 13:01   #2
tadawson
Generic Chinese OBD-II turd? Generic OBD-II won't talk to anything but the ECU, so not unexpected . . . (and the cheezy ones have other problems as well.) Find someone with VCDS, should be a non issue . . .
tadawson is offline   Reply With Quote
Old July 17th, 2017, 13:17   #3
Tdijarhead
Cheap chinese only speak chinese, you need German speaking code reader like this.
http://www.ross-tech.com/
Old July 17th, 2017, 13:33   #4
whitedog
Your title says it all. It is an OBD reader which only reads emission codes when your trouble is with the airbags which are not emissions related.
Can rent movies at BlockBuster.
whitedog is offline   Reply With Quote
Old October 8th, 2017, 13:51   #5
Nevada_TDI
You could buy Torque Pro and a Bluetooth dongle for your phone and fix the problem that way. I have both VCDS and Torque Pro and have not found an error Torque Pro would not reset.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Old October 8th, 2017, 15:53   #6
tadawson
Dorque won't talk to anything other than the ECU/powertrain . . . It's just another flavor of generic OBD-II, with *ZERO* VAG capabilities, sorry . . . . VCDS is *the* ticket for these cars . . . .
Old October 9th, 2017, 10:10   #7
Nevada_TDI
I guess that settles it, Torque Pro is much more limited than I thought; I apologize for that. I will say if you are going to own a VAG car, unless you are very close to a TDIClub member that owns one, you should save up if necessary to buy VCDS; one trip to the dealer to get codes checked or fixed is more than 1/2 the cost of the basic VCDS.
_______________
Old October 10th, 2017, 00:02   #8
Ol'Rattler
Ol'Rattler's Avatar
Does your reader set a DTC (code) and what is the number? Even with VCDS, if a fault is still active, it might clear and then come right back immediately. What year is your car? On some of the earlier cars there is a warning not to scan the airbags because scanning can brick the airbag controller.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old October 10th, 2017, 19:50   #9
jef@rosstech
Associate Ross-Tech Vendor
The issue was, if one of those buggy airbag modules is called out to for scanning a few times in a row without getting a proper connection, a glitch in the airbag module would cause said module to brick. It didn't matter what kind of scan tool was used.
However, this hasn't been an issue for Ross-Tech customers since 2004. We made a change in how our software interacts with airbag modules and if things aren't going smoothly right off the bat, VCDS stops trying to scan the airbag module before the glitch could get triggered. As best I know, no Ross-Tech customers had the issue after version 404 (April 2004) and we are now on version 17.8.0 (August 2017).
http://www.ross-tech.com/vag-com/vw_issues.html
Regards.
Jef blah blah blah
www.Ross-Tech.com
What should you do first with VCDS? AUTOSCAN!
jef@rosstech is offline   Reply With Quote
Old October 16th, 2017, 10:04   #10
jimgolf
hi Jef, could you say if this fix is also in VCDS-Lite 1.2 ?
Thanks.
jimgolf is offline   Reply With Quote
Old October 17th, 2017, 06:18   #11
jef@rosstech
Thanks.
Yes, VCDS-Lite has the same safety net feature for the old airbag glitch.
Jef blah blah blah
www.Ross-Tech.com
05 Passat Engine/Emissions and Faulty Air Bag light? Mick05TDI TDI 101 4 May 23rd, 2017 19:31
Air Bag Light Code 01217 Dean freeman TDI 101 0 May 14th, 2016 20:03
Kerma tdi cannbus vw U281 trouble code reader brann524 OBD Scanners 0 February 4th, 2011 17:47
air bag light on but no error code ken.fresno-tdi VW MKIV-A4 TDIs (VE and PD) 0 August 1st, 2007 18:11
Driving with a faulty air bag? BigDukeSix VW MKIV-A4 TDIs (VE and PD) 2 October 11th, 2001 03:48
Page generated in 0.19556 seconds with 13 queries
[Output: 102.85 Kb. compressed to 86.87 Kb. by saving 15.98 Kb. (15.54%)]
