frambach
I'm putting an ALH into a Toyota pickup. It's an ongoing process that's been going forever. My problem does not seem to have to do with the chassis. So, I'm posting here in this section.
Well, I'm finally to the point where I was ready to double check my cooling system plumbing.
I dug out my trusty Air Lift to put a vacuum on the system and I can't get it to obtain even 1psi of vacuum!
So, since this is a project, I figured I goofed up somewhere. I took the coolant manifold off the back of the head and checked it. It was fine and the (new) o-ring was not damaged. But, I did find where I had not tightened the thermocouple for my McNally gauge.
I did the happy dance thinking that was it... NO, it wasn't.
L.O.N.G. story short. I've tracked the leak to the area under the injection pump near either the thermostat or where the "crossover" pipe comes into the engine block right by the t-stat.
I have a new t-stat, new t-stat o-ring, new t-stat housing, and I've locked the t-stat onto the plastic "ears" in the housing. So, I think it's good.
Moving on to the crossover pipe. I have a new o-ring on it and when installing it, it feels secure.
More info on the crossover pipe: this is a cut up OEM pipe. I chose to cut it off right before it would go over the bellhousing and I welded a solid, circular steel disk there to close it up. It's not leaking from that end and that end is secured in the OEM location (the 11mm bolt at the tail end of the block).
The crossover pipe only has two places coolant hoses come into it now. One is the return from the Toyota heater core and the other is the return from the VW heat exchanger/oil cooler. Those all check out OK.
Once the crossover pipe has been removed, it checks out OK - holds vacuum.
The leak definitely seems to be under the accessory bracket. Can anyone please help me think of something that I'm missing?
Since it won't even pull 1lb of vacuum when everything is installed, this is a BIG leak. Is there some sort of plug or hose or something that I'm missing?
