IllinoisFarmer
I'm new to TDI CLUB...so here's some random background/observations of my life with VW:
In 1978, I was a 23 y/o kid looking for cheap transportation (the "gas shortage" of 1973 was fresh in my mind)....so after college I bought:
- 1978 VW Rabbit diesel (no such thing as a TDI, just a 4 cyl diesel w/o a turbo
- It had no air conditioner - but you could "add on" an aftermarket unit which I did and installed it myself. The A/C was pathetic
- You rolled up the windows by hand
- 4 speed stick was standard. There was no automatic
- Diesel fuel was 55 cents in 1978
- The Rabbit would freeze up when the temp approached zero...so I would drive to work and leave it running all day in the parking lot (just like the truckers) with the heater going full blast. At the end of a 9 hour day I came out to a warm car. Then I would fill up...only 2 to 3 gals used all day running!
- The Rabbit always got 50 + mpg...one time I got 59 on a trip
- It was fun to "smoke" other drivers. Flooring the Rabbit would cause it to blow clouds of nice black smoke.
- The Rabbit was sloooow.
I never lost my affection for VW diesels, so on Oct 27th, I bought a 2015 Passat SE w/sunroof. What a difference from 1978! A few observations so far.
- As a "do it yourselfer" I have an oil change pit in my garage. I pulled the Passat onto the pit and climbed underneath for a look how the engine/oil filter looked. Surprise...you can't see the engine from below because the entire belly of the car and wheel wells have plastic shields covering the sheet metal. The plastic shields are a great feature....ordinary vehicles have little or no underbody protection. Gravel hits underneath...paint is chipped off....rust begins....can't happen with a Passat! Winter road salt is common after snow....what happens when salt finds chipped paint? Besides the plastic shields, the other thing you see it LOTS of aluminum heat shields...all the way from the engine to the tailpipe. THIS CAR IS BUILT LIKE A TANK!
- I found out the high flow diesel pumps (large nozzle) don't play nice. I ordered a VW/AUDI adapter from Amazon
- Since a new engine typically burns some oil, I ordered a case of Castrol 507.00 oil to keep it filled. 10,000 miles is a long ways off!
- I paid $27,083 plus tax
- It's great being in a Volkswagen again!
