Old December 16th, 2017, 10:02   #1
Jfritz33
Default HELP! M-TDI swap in Toyota wonít run
Hey there I put a 98 1.9L M-TDI in my Toyota pickup and it wonít stay running. I just swapped all new fuel lines, new fuel filter and housing, and bled the injector lines. I have a clear in line fuel filter under he hood and it has constant fuel going through it. Itís like it gets warm and gen shuts off. I put a mechanical pump on it and got rid of all the electronics. Iím going to try and post a video on here but if not my phone number is(360) 901-8584 and you can text me and Iíll send the video.
Jfritz33 is offline   Reply With Quote
Old December 16th, 2017, 10:03   #2
Jfritz33
https://youtu.be/0EvhcibfAfE
Old December 20th, 2017, 17:50   #3
ToddA1
Fuel Economy: Dismal
Very odd... if it starts and runs, how long does it stay running without any help?
Have you tried running it off a jug, bypassing the entire Toyota fuel system?
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is online now   Reply With Quote
Old December 20th, 2017, 19:05   #4
jimbote
jimbote's Avatar
really sounds like it's running out of fuel
jimbote is offline   Reply With Quote
Old March 26th, 2018, 20:29   #5
Jfritz33
Still doing the same thing, thought it was the injection pump and got it fixed and still wonít stay running for more than a minute. Do you think the stock Toyota fuel lines would restrict fuel from the tank. I have a 4-6PSI trash pump right before the fuel tank to push it to the pump.
Old March 26th, 2018, 20:52   #6
Motohead1
Did you run it on a jug?
Dodge Dakota QC Tdi
Motohead1 is offline   Reply With Quote
Old March 27th, 2018, 00:04   #7
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Fuel Economy: pending
Could the fuel lines be reversed?
1.9ZOOK is offline   Reply With Quote
Old March 27th, 2018, 20:02   #8
andy2
andy2's Avatar
Make sure that the "in" and "out" banjo bolts are in their correct locations on the injection pump !
andy2 is offline   Reply With Quote
Old March 27th, 2018, 21:07   #9
QuickTD
And make sure you are using a proper "OUT" bolt, with the screen and tiny orifice.
I've seen the "OUT" bolt discarded and replaced with a regular banjo bolt. With no pump housing pressure the engine won't run properly, if it runs at all.
QuickTD is offline   Reply With Quote
M-TDI 1.9 swap Toyota pickup Jfritz33 TDI 101 5 September 1st, 2017 20:00
And yet another Toyota swap, but M-Tdi. JaysinSpaceman TDI Conversions 289 May 10th, 2016 17:18
Newest Toyota with a tdi swap bbob203 TDI Conversions 3 December 6th, 2014 10:48
tdi into toyota swap need help 85customcab TDI Conversions 22 April 25th, 2013 08:38
toyota 4runner tdi swap invalid TDI Conversions 13 April 10th, 2013 12:13
Page generated in 0.14022 seconds with 13 queries
[Output: 88.98 Kb. compressed to 76.07 Kb. by saving 12.91 Kb. (14.50%)]
