keaton
On my MK5 TDI I was able to set the approach so when I press the unlock button my keyfob the low beams would also kick on along with the interior lights.
I was in the car computer with VCDS and found the bits for both approach lights and coming home lights. but only the coming home lights work.
is there extra settings/bits to hit for this?
coming home lights: pull the high beam flash after the car is off and the head lights kick on for ~30 seconds even after you lock the car.
