1300 eh? What does it run at during normal highway cruise? Mine would only top 900 on a hill climb at highway speed. Now that I have the injectors, it will hit 1000 easily on the highway. What kind of IAT's are you seeing?
I'm definitely down for some TDI trail running. PA would be about as far as I'd run south for a weekend get together I think. I definitely need to clean the TDI/Jeep parts out the garage too. lol
If your ecu tuned? Still running the vnt15? Those egt's aren't terrible for an aerodynamic brick that weights 1000+lb more than a golf/jetta.
When the wife is gone for a couple of hours, swap out her 11mm pump and put your old 5 spd nozzles in there. Exact same power combo as she had before. She'll never know you did anything
. (My girlfriend still doesn't know her 11mm from her auto ended up in my roommates 99.5 5 spd with a 2056vk haha. I threw in a set of pp520s to make up for stealing the pump
To get egt's down, a tune will greatly help if you've put injectors in it. From there, a Colt cam will drop egt's 100-150F and add 10-15whp (according to my dyno testing). From there, I would add a 1756vk turbo which would drop egt's further for the same power levels and add quite a bit of scoot to boot!
My roommates car is a perfect example of a setup that works very well together. It has a 11mm pump, pp764's, mercedes 2056vk, ported head, colt cam, stock intake, stock IC, and straight exhaust. Cruising down the highway at 75mph, egt's sit at 600-626F and we can't manage to peak 1250F. The combo is basically smokeless and the turbo starts boosting at 1800rpm and has full boost by 2200rpm.
I need to check my IAT's ...but I am also running a 12mm pump ...so I'm most likely overfueling....gonna swap in a 10mm in a week or so....cruising flat @ 75 somewhere around 750 to 800 but it climbs quickly on a grade
Don't swap out the 12!!! Did you get the thing tuned yet!? The torque difference between an 11 and a 12 with proper tunes is crazy. I can only imagine how nutless the truck would feel with a 10mm. You need some arp head studs, race 520's, and a 2260vk on that thing Jim! A yota with a smokeless 200hp/375tq would be an abosolute riot! With your bottom end and injection pump you're already mostly set up for it!
Egt's are going to climb quickly on a grade when you're driving a brick. Same thing when towing with my jetta; 800-900F on flat ground and 1100-1200F going up small hills towing 2 sport atv's on a 6x8 trailer. About 4000lbs total load.
