i just replaced my control arms, pads, rotors, and brake lines in my mk4 this past week. other than a snapped nut in the control arm, everything went smooth. i connected the sensor in the drivers inside brake pad to the connector, and when i started the car up i had the "low brake pad" indicator light, along with a flashing and beeping brake light. i disabled the low brake indicator using vcds, but i'm still having issues with the brake light. every once in a while it turns on and begins flashing and beeping, then turns itself off. anyone have any ideas?
