jimigunne
This rapid knock sound with vibration (and a sort of whir-whir or scrape-scrape sound without vibration at slow speeds) developed gradually. I detail all done, parts replaced in my first ppost on drive axle wobble. I was
Its not cupped tires causing the vibration, but the lh outer cv joint is wobbling a lot as it turns. I confirmed this visually by velcro'ing a 4k action cam to the lh forward wheel well and driving car. After replacing both the lh cv driveaxle and the lh hub/ bearing assy (both new from O Reilleys') i still have the same wobble/ vibration! What could cause the outer cv joint to wobble. Seems like it would have to be either driveaxle or hub/ bearing. I am replacing the lh strut now, followed by rh strut. But not much expecting that to make the cv joint run true again.
