MECAMINO
Ony one in the Windsor, ON area that can lend tools over the weekend for timing belt set up?
Car would not start last week during the sub zero weather. Pushed the car into the garage and fired it up the next morning, #@!#@ put it this way car sounded like tin cans smashing against each other???
Later during the weekend I pull the timing belt cover off, established top dead center on the cam and injector pump - found the crank to be retard 3 teeth.
I found the belt tensioner or the person who did the timing belt last at fault - The notch and the groove on the tensioner do not line up and the metel hockey stick looking retainer clip bent over rubbing against he tentioner and fraying the belt.
My mission is to set the crank and fire it up??? if it sound good I will buy new belt and tensioner if not - car may be going for sale.
I think I will be ok beacuse the HYD lifters can absorb a little push from the pistons, but the proof is in the pudding when she calls for fire in the hole...
Has anyone had this experience on a 97 Passat??
