gforce1108
- Joined
- Aug 2, 2006
- Location
- Newburgh, NY
- TDI
- 04 Jetta GLS BEW, 14 Audi A7 V6 TDI, 13 Porsche Cayenne V6 TDI
Almost titled this "the tale of two limping unicorns"
I have two nearly identical cars with the same problem (overboosting). Both pass MAF, N75 tests, vacuum tests and VNT start/stop pressures (one is a little slow to move at first, but returns quickly).
Both will overboost at higher RPMs, especially in 4th gear.
My buddy and I both have 2003 Reflex Silver ALH 5sp GLS wagons - only differences is his has black leather and traction control with 225k miles, mine has grey leather with 304k miles.
I had him come over last weekend to diagnose his limp mode. I figured something would come up quick, but everything passed the tests. I searched for the lesser known causes to overboosting and came across clogged intake or exhaust. I almost ruled them out.... I put a new downpipe/cat on his car maybe 30k ago. I also did the last timing belt and a full intake cleaning (including the ports in the head and EGR) maybe 40k ago.
I pulled the EGR and there was maybe a little over 1/4" of buildup, but figured I'd clean it while I was in there. I reached in with a bent over screwdriver while vacuuming and cleaned what I could and reassembled.
I could not get it to overboost again. I did a full throttle 1st through 4th blast on the highway in the exact same manner/place as when I was logging it and easily caused limp mode.
If this was enough to cause the problem, I can only imagine what mine looks like!!! (Purchased with 303k, in limp from bad MAF - I did the last 2 timing belts but never cleaned the intake. VW rebuilt the motor around 100k when the timing belt broke so maybe it was cleaned 200k ago?)
