This is a good write-up and plan on getting some contact goop for my glowplug-harness connectors soon.
Being trained in electronics and military soldering, I feel compelled to make some comments. Keep in mind that I have been troubleshooting million-dollar computers for many years and have been known to isolate/resolve automotive electrical issues that had other folks stumped. I know 100s of ways to take voltage measurements to isolate a problem in a live circuit.
The crimp-on connections are used by jobbers because it is quick, It is NEVER better than soldering. Taking the time to solder all connecitons makes a huge difference in reliability.
Using CRIMP-ON connecitons at any point under the hood is asking for trouble. I realize that portion of your write-up is from your original harness replacement but instead of having essentually 4 crimp-on connecitons (2 butt crimps per connection) i suggest that a standard twist-together and solder would be infinetly more reliable. This is especially true under high-current conditions where even a small resistance can become a large voltage drop (ohms law)
This URL explains wire-connections and soldering.
http://www.teamrocs.com/technical/pages/connections.htm
You also mislead folks by suggesting that there is no way to "test the harness". I can think of at least 5 ways to test the harness.
Here is one way.
You can measure the voltage drop ACROSS the harness using your DVM (DigitalVoltMeter) by putting probes at both ends of the glowplug harness. (use a length of 22guage wire wrapped around glowplug to connect probe) This measurement will tell you how much voltage is LOST in the cable (due to intrinsic resistance) and not getting to the glowplugs. Again, ohms law tells us that the glowplugs must be drawing the expected current for this test to work.
Another way to "test the harness" is this;
Place DVM probes between solid ground and the glow-plug end one at a time to check the voltage at each glowplug. Any reading significantly less than battery voltage indicates there is resistance in the harness. (again use a length of 22guage wire wrapped around glowplug to connect probe)
The "secret" with testing the harness is to have the FULL CURRENT FLOWING thru it when testing. Otherwise, a 'whimpy' harness may not exibit a problem. Just checking the voltage at an unplugged harness end tells you very little about the condition of the harness. (Look up the input resistance of your DVM and compare that to harness resistance to see what I mean)
You do realize every connector in the car is a crimp connector right?If anyone who called himself a "mechanic" used but connectors to install my new glow plug harness (or ANYTHING on a car) I'd kick him in the crotch, refuse to pay him and tell him to buy a soldering gun.
Using those crappy terminals is NOT the way to work on your car. That's why they invented soldering guns, solder and heat-shrink tubing.
If it's worth doing it's worth doing the right way.
I've always wanted to do this, but I also couldn't stand putting US threads on a metric car. However, by fluke, I was browsing through a manufacturers catalogs and noted they sold glow plugs.For your purposes ignore the red wires in the above picture... that's my harness delete. I've threaded the tops of my glowplugs for 8/32 Kepps nuts and run individual spade lug terminals... another option for those so inclined
Idle speed should be 903. You can drive forever with a glow plug light on.Is it ok to drive 1300 miles, when the engine light is on? The code is for a glow plug. The car (2003 tdi Jetta) is running and starting just fine, except for a slightly higher idle speed - 900 rpm's. Thanks.
I'm having the same problem as the poster above, and hope that one or more of you experienced folks on the forum could help out us non-experts. The trouble we are having is simply removing the glow plug connectors and then the glow plugs without causing damage to any delicate bits of the plug or harness. The plastic connector is very resistant to careful pulling.New to the forum, and this is my first diesel.
CEL is on and codes all point to the #1 glowplug.
Followed a guide to getting access to the plugs, but once I've loosened everything to give the harness enough play to remove the plugs, I'm not able to actually pull them out.
Not sure if I'm missing something to disengage a clip on them or if there is something wrong that is preventing them from coming loose with the amount of force I am applying (which I think is considerable given that I haven't seen anyone else with a similar issue).
Any help would be appreciated from anyone that has removed them to test them.
Thanks.
I should do a scope output of the hall effect sensor to see what RPM actually idle is at. The value of "903" is a byproduct of 8-bit digitization as the ECU sees a value of 43 and the RPM interval is set at 21. Once multiplied together you get 903. It's simple aliasing.Idle speed should be 903. You can drive forever with a glow plug light on.
However, get your ohm meter and ohm the four out. They should all be less than 1 ohm and close together with respect to the readings. Any big deviation means you likely found the cause of the light.
If they all check out, it's likely a harness or connection issue.
Do you have vcds?
^^^^^ Exactly my thoughts. My 2004 PD has been intermittently throwing a P0671 code for a few weeks. It hasn't been an issue since it lives in the temperate tropics (South Florida). When I clear it, the code doesn't always recur on the next startup, but it was getting annoying. The real reason I care: On the rare occasion my wife drives my TDI (rather than her's), she comments about the CEL in my car.Wingnut, I know this is an old post just wanted to say Thank You, you Saved me a lot of trouble!!
Hi all, thanks for the tutorial, it helped a lot. However I ran into a problem that I can't figure out. I had 1 bad glow plug giving me a cel, and my harness was kind of a mess so I got 4 new Bosch plugs and oem harness. Car is 03. Now I have no power to the harness, the new wires are good I tested them. Fuses at battery are fine. Got a new Bosch relay, and it didn't fix my problem. Any suggestions?
(I've been reading the forum for years and learned a lot, thanks for all the great threads and diys. I also have a b5 Passat waiting for a kit from Frans, 6speed, Avg engine)
Do understand correctly that circuit goes like this:Follow the wiring back from the fuse, it must be shorted out somewhere
