So i have a 01 Audi TT Quattro with that i am swapping with my 2000 Vw Golf Tdi .
And here will be where all the photos will be when I start
http://s79.photobucket.com/user/matthunter1448/library/audi%20tt%20tdi%20conversion
I will be starting the swap here soon so any insight i could use.
First off for gearing i am getting a gears from a 02m fwd tdi tranny(ryanp) and swapping them with my awd 02m so i have the correct ratio for the tdi engine. At the same time i will be putting a peloquin diff in.
Engine is a direct swap in so that makes that simple, i will be upgrading the clutch as well
Next is wiring
Not really sure on this yet could use some help. From what i have read it's basically a direct swap but want to make sure before getting that far.
The tdi will have a immobilzer delete to make things more simple as well.
Fuel system i will be swapping everything from my golf from the fuel tank sender to the fuel filter, lines and all. to make it simple
Exhaust i will be using a downpipe from darksidedevelopments.co.uk
i will also in this venture be upgrading the turbo and fuel nozzles and hoping to make 200hp.
That's all for now pics will come soon when i start and hopefully more info so future people can do this like me.
Next is wiring
