Old December 1st, 2018, 15:49   #1
joecitizennn
TDI(s): jetta
Default Single mass flywheel on a PD
I have a clunk in my dual mass flywheel on my 2005 mk4 tdi. I have been debating on single mass vs dual mass as a replacement. I really want to put a single mass on it because of the reduced cost and increased simplicity (aka... never have to replace it again), however there seems to be alot indicating that the dual mass is a vibration dampener as well as making clutch engagement softer. I have heard many claims that going to a single mass on a driveline designed for a dual mass can cause accelerated vibrational wear, especially to the transmission. Is everyone in agreement with this? Has anybody here gone single mass on a PD TDI and observed several hundred thousand miles of service with one? If so... what say you?
joecitizennn is offline   Reply With Quote
Old December 2nd, 2018, 07:31   #2
dandywriter
Sample size of one...
Switched from DMF at 87,000km/54,000mi; now have 245,000km/152,000mi on SMF conversion (Valeo) with no issues. I did get a 21lb flywheel - I imagine the greater violence of the ignition in diesels would not be so kind to very light flywheels - having mass there to soak it up seems a good idea to me. Great clutch feel in comparison with original clutch. To my ear, SMF is quiet - no rattle.
I've never heard anything about increased vibrational wear to the transmission from an SMF conversion.
2006 Jetta TDI 5-sp, Bosal hitch, frostheater, evo skidplate, upgraded rear springs and front spring dist kit (1" lift), GIAC Stg 1 tune, USA Spec iPod adapter, SMF clutch, Coolant Heater Grill Outlet, winter front, LED backup and lic lights, VCDS
dandywriter is offline   Reply With Quote
Old December 2nd, 2018, 14:02   #3
Ol'Rattler
Ol'Rattler's Avatar
That applies to the syncros in the 6 speed, not the 5 speed. Apparently a SMF will beat the syncros in a 6 speed to death.
Go with this one: https://www.idparts.com/sachs-quiet-...a5-p-2831.html
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old December 2nd, 2018, 19:13   #4
joecitizennn
TDI(s): jetta
Good information. I trolled the internet for days reading and found only conflicting information. Sometimes it is best just to ask.
Old December 6th, 2018, 11:15   #5
ToxicDoc
TDI(s): 2001 Jetta
Your stock flywheel has 13 years and however many miles. I would think a stock replacement would serve you just fine, no? By the time it's up for replacement you may be up for another vehicle.
ToxicDoc is offline   Reply With Quote
Old December 7th, 2018, 17:01   #6
Ol'Rattler
Ol'Rattler's Avatar
IDK about anyone else, but the DMF on my 2006 BRM was just horrid to drive. People would say that it's a Diesel so you have to drive it differently. Complete nonsense. I replaced the DMF with a SMF at 55K miles because the DMF was just a chore to drive in traffic.
I wish that the quite clutch was available back then but other than some gear jangle at idle, the SMF is a joy to drive. I'm at 188K miles total car mileage and the clutch has been bullet proof. I still have the DMF setup with 55K miles on it and would give it away to anyone that might want it.
Mine never made a clunking sound but driving it from day one was just horrible. If your DMF is making a clunking sound, it's probably on it's way to grenading which will probably punch a hole in your bell housing.
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old December 7th, 2018, 17:47   #7
SMF setup in your car will be totally fine. It'll drive as well if not better than a DMF and it won't wear any components any faster in your car.
However, if the car is stock you might also consider the LUK DMF kit 17-050. Very smooth and quiet, and inexpensive. It can't hold a lot of power, but for a stock or mildly tuned car it's fine. And it'll probably last for as long as you care to keep the car.
You have options.
Sachs Single mass flywheel kit w/flywheel Vertexboy Private TDI Items for Sale/Wanted 1 December 24th, 2015 08:11
dual mass flywheel failure/single mass conversion bassman5066 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 10 October 22nd, 2012 15:41
Single mass vs. Dual mass flywheel??? Btdi Upgrades (non TDI Engine related) 17 May 25th, 2012 06:42
dual mass or single mass flywheel tdicanboro VW MKV-A5 Golf/Jettas 5 February 25th, 2011 09:37
dual mass flywheel to single flywheel conversion vdubdezl TDI 101 16 December 23rd, 2010 05:27
Page generated in 0.12790 seconds with 12 queries
[Output: 83.83 Kb. compressed to 73.10 Kb. by saving 10.72 Kb. (12.79%)]
