Squibals
2002 jetta tdi. I did the brake booster. The thing is the car sat for a while. Now it's leaking fluid where the fluid line goes into the slave cylinder and the clutch just goes to the floor and stays. Appears to be leaking right at what seems to be a plastic piece the fluid line goes into. Right next to the bleeder. Can a slave cylinder go bad while sitting 5 months?? Can I just repair that connection.??
