Best cold air intake
WildChild80
Nashville, AR
2001 Jetta TDI 2000 Jetta TDI 2000 New Beetle TDI ALL 5 speeds
You've gotta be specific, are you looking to add power? How much power...alh or bew, 5 speed or auto
If you want help give us some bones
Edit:. Didn't notice what thread this was in...no clue what you want
Sent from my Pixel XL using Tapatalk
Oulie2309
Corpus Christi texas
2012 Golf
2012 golf auto...I’m looking to increase mpg and power..i don’t wanna do anything that will void warranty due to the lifetime drivetrain warranty
WildChild80
Nashville, AR
I'd contact kerma or Malone and get a tune from one of them, that'll get you more power and efficiently. A tune will be the easiest reversible power adder.
Rrusse11
PA Deutsch Country
2002 Golf, 5spd; 05 Jeep CRD
Stage 2 tune, malonetuning.com. Responsive and from all reports,
give good service.
Research these forums, there's a LOT of information to absorb.
Like I said before, read the thread at the top of this forum about
cold air intakes. Then I highly recommend this thread:
http://forums.tdiclub.com/showthread.php?t=133342
That'll keep you busy. Lol, then get back to us. TDIs are a different
animal than the gasser world.
  • Like
Reactions: Ton
Oulie2309
2012 Golf
Iv owned diesels all my life just nvr nothing this small ?...i currently have a 2018 Cummings with a 10” lift on 40s but my drive to work is 7hrs every 2 weeks so I figured I’d get a tdi ??
Oulie2309
2012 Golf
So before i start another stupid already answered thread...can some one show me the way to a tire and wheel thread...what’s the widest tire and wheel that can be put on these cars...thanks in advance
  • Like
Reactions: Ton
Will Halsey
Wyomissing, Pennsylvania
MK6 Golf 4-door
If you want a cheaper all around good cold air intake look at AFE intakes. They gain some power and create a nice blow off sound for mk6's. But i would start with a tune before you do that.
  • Like
Reactions: Ton
Ol'Rattler
PNA
2006 BRM Jetta
Designed to separate people that drive Brodozer trucks from their money. Notice that the claimed performance gains state "up to" XXX performance gains which is a meaningless statement.. https://afepower.com/cold-air-intake-systems
A chip tune would give you actual performance gains with your factory CAI that would put a smile on your face..............
  • Like
Reactions: Ton
GoFaster
Moderator at Large
Brampton, Ontario, Canada
2006 Jetta TDI
Then leave it absolutely stock. There is nothing to be gained by changing the air intake.
VW will use any excuse to deny warranty coverage. If warranty coverage is paramount ... leave it absolutely stock. Don't touch a thing outside of documented scheduled maintenance.
  • Like
Reactions: Ton
GreenLantern_TDI
Iowa
2015 GOLF SEL
This. If you want to keep your warranty just drive it and maintain it as VW produced it.
OR
From the info on your "Cummings" youve got alota money to blow so forget the warranty and mod it into a coma with a turbo eater 5000 CAI and a nice Stage 2 custom tune with DPF delete kit with larger turbo. That should eat about $5000 to start. Then a new turbo every couple years there after at $1000 a pop till ya put the factory air cleaner back on.
AND
A guy can also get bag kits or hydraulics to get the oil pan as low to the ground as you can and this would support many spinner wheel options. Maybe some dubs with 235/10-22 bands as well.
Happy motoring and welcome to the club.
  • Like
Reactions: Ton
jhax
Golden, CO
96 Passat B4V, ALH engine out of a 2002 Jetta, some IE Rods and ASV Pistons. Nothing drivable yet though
This thread... is turning out to be... GREAT!
  • Like
Reactions: Ton
740GLE
NH
let me get this straight, you want a CAI for MPG gains, but then you also want wider tires for what? looks? handling?
You're two statements are counter productive, but at least a nice set of wheels will actually do something as you can look at them way more than a CAI,
That being said, you can prob find some VW Cadiz which are 19x9 ET50 that will technically fit but are stupid to own.
That being said 17x8 would be a nice meaty wheel that would still offer decent sidewall depending on tire, don't fear going up in size, 26.5" diameter will fit.
Take a look at these, you'll need 5x112 bolt specs, they are pretty common for VWs, pretty much anything that works for GTIs will work on this platform, but be warned they will take an MPG hit.
https://konigwheels.com/wheels/flow-formed-wheels/hypergram/
  • Like
Reactions: Ton
oilhammer
outside St Louis, MO
Not only a MPG hit, but harsher ride, noisier, much more expensive tires with much shorter life. A lot of cons and very little pro.
740GLE
NH
"bro sweet wheels" - pro!
as for fitting taller rubber, (225-55-17 will be going on the Alltrack next year) that should help with ride but yeah can't do anything with price of 17"
I figure if he's willing to spend money on a CAI, he's willing to spend money on just about anything "cool".
  • Like
Reactions: Ton
eddieleephd
Battle Ground, Wa
2002 jetta Wagon
https://cse.google.com/cse?q=+&cx=018097697432185261444:_idbzjdyxdm
This is the search engine linked at the top of TDI 101, it's my best friend.
Reality is that these car's benefit most in tuning and turbos. The second would be the exhaust and reduction of the back pressure.
At the top of upgrade section there's a whole write-up about the initial modifications and their benefit.
The other post worth reading is the best cold air intake stickied at the top of this forum.
Read stickied threads on the top of every forum first. Most of the information you want is located there, check it out, all of them please. For your most possible benefit and ours!
Sent from my Armor_2 using Tapatalk
Mongler98
COLORADO (SE of Denver)
New to the tdi world..what’s the best intake for these motors...thanks
there is no such thing. Only thing that comes close is the swiss cheese mod for your air box but just leave it stock.
here read up on this and dont buy ricer parts that were made to sell at pepboys, use the parts that were made by multi billion $ companies whose job it is to make car parts.
you think you know more about a car part like an air filter then the engineer who made his career on this one part? I THINK NOT.
CAI are a scam, reduce power, damage engine internals, and ruin MAF's
http://forums.tdiclub.com/showthread.php?t=290373
  • Like
Reactions: Ton
andreigbs
Walworth Co., Wisconsin
N/A
"I don't want to void my warranty. Help me pick a not OEM quality part which will absolutely allow more debris into my turbo and engine. I know all about Diesels- I have a Duramacks"
You win the best comment prize.
Guys, I think he meant the Cummings Durex has taught him how to "mod" diesels, so how hard can a TDI be??
Great thread, needed the laughs.
And still laughing...
shanky887614
uk
vw caddy arl
the oem one doesnt start to become a restriction untill after 300bhp
Sent from my ASUS_X00ID using Tapatalk
