barrel roll
I've a 05 b5.5 Passat tdi. Malone tune lvl 1.5, BSM deleted, 5 micron fuel filter, Thor skid plate, and a rear sway bar.
My problem occurs randomly when I am stopped at a light. It feels like a gasoline engine missing: the rpms drop suddenly then pick back up. It throws no codes (checked with vagcom), even though it has caused me to stall out. The egr valve (my initial thought) is clean. The tandem pump and MAF are new. Torsion value is within specs, aND injector values are as well.
What do you think it may be? What do you recommend I check, or do to troubleshoot? What sensors should I log?
TIA
TIA
