B bookem34 Active member Joined Feb 11, 2014 Location sarver pa TDI 2000 jetta Jan 12, 2018 #1 Can anyone which solenoid is considered "A" in the valve body in a 2000 jetta?
J joetdi Veteran Member Joined Mar 8, 2008 Location Midwest TDI 2-2002 Jettas W/Auto Jan 13, 2018 #2 I believe it is N91 on the end, toward the 2 valves on the other side if that makes sense. It should have about 5 ohms.
B bookem34 Active member Joined Feb 11, 2014 Location sarver pa TDI 2000 jetta Jan 13, 2018 #3 makes perfect sense. thank you
