Old August 1st, 2017, 17:39   #91
UhOh
UhOh's Avatar
That's confusing
Lemforder doesn't make Cupra R axle bushings that I'm aware of. And everything that I've ever read says that the Cupras are solid (it's the orientation of voids in the others that requires special alignment). I've installed two sets of the Cupras and neither set came with any information, no orientation noted. I did, however, line up the aluminum ears on the bolt sleeve such that they pointed at the magic points on the axle beam.
UhOh is offline   Reply With Quote
Old August 1st, 2017, 17:44   #92
gmenounos
The Lemforder photo was just to show the orientation of the center line with the axle. The first photo shows the center line and the supposed voids. In the interest of science, someone should cut one of the Cupra bushings open to see what it looks like inside.
https://www.bitfab.com/tdi
gmenounos is offline   Reply With Quote
Old August 1st, 2017, 18:12   #93
UhOh
UhOh's Avatar
Why not use a photo from one of the bushings in question?
From https://www.cascadegerman.com/product/6ll501541-set/
Solid rear axle beam bushing set from the SEAT Ibiza Cupra R. Much stiffer than the OEM bushing, this is a great upgrade to make your car smoother over rough terrain. [emphasis added]
Old October 12th, 2019, 13:08   #94
Gothmolly
TDI(s): 2002 Golf
Bumping thread.
My car is really "stiff" in the back, like when I hit a bump the whole car bounces. In the past, when I've done shocks and replaced the springs, when I undid the bolts the axle wouldn't drop enough for me to get the spring out/in, I had to have someone basically stand on the axle to get enough clearance. It's like the rear axle isn't moving up and down - hence the massive bumps transmitted to the car.
Could this be bad bushings? Car has 230K.
!Vent, !DRL, 5 brake light mod, 11mm pump, RC3, Bosio Sprint 520s, VR6/G60 clutch, dead AC, leaking oil cooler, missing belly pan, leaky CCV, leaky valve cover, leaking door seals, broken glovebox, broken horn, rusted fender, dead rear windowwasher, frozen axle bushings
Dead radio? Pull fuse 42, wait 60 seconds.
Gothmolly is offline   Reply With Quote
Old October 13th, 2019, 06:16   #95
Yourbuddysatin
Fuel Economy: 32-35mpg
The bushings are probably seized to the bolts. I recommend poly bushings from ecstuning. Easy to install and stiffin up the beam.. The bouncing sounds like bad struts though.
Yourbuddysatin is offline   Reply With Quote
Old October 13th, 2019, 10:03   #96
Gothmolly
TDI(s): 2002 Golf
Thanks - the shocks/struts/springs are about 50k old - and I replaced them because the back was so stuff on bumps.
When you say "seized to the bolts", do you mean that they're supposed to pivot on the bolts themselves, vs. the rubber part of the bushing rotating/deforming within the mounts on impact?
Old October 13th, 2019, 12:26   #97
Yourbuddysatin
The center section of the stock bushings are actually aluminum from what I remember. Then the bolts are coated steel. That is the pivot point.
Old October 14th, 2019, 11:12   #98
SilverGhost
SilverGhost's Avatar
Just to clarify a couple things.
Long bolt through trailing arm bushings must be tightened at load level - weight of the car on suspension. Bushings do not pivot around the bolt in service, but will pivot around bolt when loosened. Also notice the bushings are not perfectly parallel to each other - they will bind a little as the trailing arm swings down.
Stiff suspension shouldn't bounce. Or do you mean it bounces like it has no suspension and just the tires are bouncing with bumps? Worn shocks will allow continuous bouncing or pogo'ing. Seized/frozen bolts will limit suspension movement - sounds like this is what you meant?
Also a thought - have the springs been replaced before? Possible that "towing springs" were installed and made rear end stiff? What parts source did you use when you replaced suspension? I have some standard Bilstien shock/struts that have not impressed me. Also possible that the rear have failed or are too stiff for your application?
Just running ideas out.
Jason
Old October 14th, 2019, 14:23   #99
Gothmolly
TDI(s): 2002 Golf
Jason
Thanks, I guess mean it's stiff - the car does not continue to bounce up and down, but if you hit a bump when the rear wheels hit it, the car bounces so hard you'll spill coffee. Given that when I undid the shocks the rear axle wouldn't lower enough to get the springs out, it feels like everything's frozen.
IIRC I used standard idparts.com springs for an A4 Golf. Not sure what was in there before, but both springs were broken.
Old October 15th, 2019, 09:02   #100
SilverGhost
When you "undid" the shocks, did you also loosen the long bolt through the rubber mounts? Will the bolt turn after you remove the nut? If it's seized into the mount then that could be why the arm won't droop enough to replace the springs.
Being up in RI and already having broken springs, I would guess you also need to replace the mounts and bolts. FYI - depending on which version you have, this is a PAIN IN THE ARSE job to get the old ones out. First time, and as rusty as your explanations imply, this would be a job to have a shop do. Or at least the help of someone who has the tools and has done the job before.
I have a rust free Jetta, work as a dealer, and I'm still putting it off because the job sucks!
Jason
Old October 15th, 2019, 18:31   #101
Gothmolly
TDI(s): 2002 Golf
Jason
I never touched the mounts, because I didn't want to get into a project where I don't have a driveway, or spare car, for the inevitable rusted bolt that shears off vs. unbolting.
But thanks all for confirming how the setup is supposed to work - I wont waste money on new shocks or springs! So many things are broken on this car, what's one more? At this point it's 1 blown turbo or clutch replacement away from the scrapyard.
Old October 29th, 2019, 18:26   #102
PakProtector
Have mentioned this elsewhere, but an Ajax A906 bushing splitter chisel( or a 964 if you have a big air hammer that takes .498 chisels) makes short work of the bushing removal.
cheers,
Douglas
1990 D250, NV5600, Luk 05-101, 16cm housing, TST Kit KDP tab, 366 spring, Powr-Lok'd 3.07, HX35...IC soon
She wasn't built to travel at the speed a rumour flies
2004 Jetta, 5spd...stock and turning 47-48mpg
PakProtector is online now   Reply With Quote
Rear Axle Beam Bushing - Need Help DVF2001 TDI 101 61 June 20th, 2015 08:19
Regarding rear axle beam bushing replacement. vwdieseling VW MKIV-A4 TDIs (VE and PD) 0 April 28th, 2013 01:58
Rear axle beam bushing Winkowitsch2011 TDI 101 2 June 11th, 2011 17:55
Axle beam bushing replacement willjayc TDI 101 17 September 8th, 2010 10:02
Rear Axle beam bushing 2ManyKMfor1Tank Ontario 5 May 23rd, 2010 19:39
Page generated in 0.16666 seconds with 12 queries
[Output: 116.79 Kb. compressed to 99.41 Kb. by saving 17.38 Kb. (14.88%)]
