otty
- Joined
- Nov 7, 2010
- Location
- Revelstoke, BC
- TDI
- 2003 Passat W8=>TDI swap, 4Motion Wagon, PD130(AVF) 6Speed Manual, 2006 Jetta MKIV PD(BEW) Wagon 5Speed Manual
Recently my car has begun occasionally surging while "engine braking" ie while coasting in gear (clutch engaged, no brake or accelerator pedal applied). The car gradually slows as it should and then will surge as if I had stepped on the accelerator pedal but without me touching it. It is a bit disconcerting and has been occurring with increased frequency.
Any ideas what may be going on?
Not sure if it is related but I have for the first time had the car go into limp mode recently on longer up hill drives and am having some VSS issues I think on the front driver's side wheel that set off the ABS and ESP lights.
I do have VCDS if there is a scan or module to track that someone can suggest.
Thanks!
Thanks!
