Key fob programming
fire32njetta
Central NJ..
2003 Alaska Green TDI Jetta
I heard that you can program a new key fob using VCDS. I had to get a new job for my 2003 after the key ring dropped off of my old key. How would one go about doing this programming?
2004STARWARSTDI
LAKELAND, FL
2004 Platinum Gray GLS Jetta / 2006 Silver Jetta with DSG
Key programming
Being a Veteran member you should know how to use the search function! Go to Ross-Tech: Home type in key programming & all will be explained to you.
