crimsonguard6
2005 Passat TDI w/ about 165k miles, BSM delete.
Wife was driving it a couple days ago, went around a corner and thought she hit a pothole because she felt a thunk and it was very sluggish. Drove it to the side of the road, stopped it and had it towed to a mechanic.
Troubleshooting so far by the mechanic.
Gear 2: Incorrect Ratio, Mechanical Failure
Gear 3: Incorrect Ratio, Mechanical Failure
He cleared the codes drove it and it immediately went to overdrive. I sent him this link about TCM issues, http://forums.tdiclub.com/showthread.php?t=311922&highlight=2005+transmission+problem , and he said the TCM is dry. Next is to check the wires in the passenger door. If no problems there, where else would you suggest looking? I'm also thinking of dropping the pan to see what the oil looks like and if there is metal in there. Fluid was changed about 3 yrs. and 25k miles ago.
