Old June 2nd, 2017, 08:38   #46
Layerz
Nice, how did you plot the Butt Dyno? I have a spread sheet I've used before that's fun with my VCDS laggy inputs - need to average some groups.
Layerz is offline   Reply With Quote
Old June 2nd, 2017, 10:04   #47
eddie_1
eddie_1's Avatar
Hi, The spreadsheet I used orginated from Rosstech themselves. I think one of their guys put it together. (I tried a couple of other freebies but did not look right.)
http://www.ross-tech.net/vag-com/examples/dynoplot6.xls
Here he explains how the math is done:
https://www.audiworld.com/forums/vag...tions-2580766/
Basically you do an acceleration followed by coasting to subtract the losses. I found in 3rd gear the results were smoother.
The Insoric method I think is no different except their uProc based sensor on the wheel is very very accurate to get the revs upto 1KHz sampling and then to calculate the speed. The more accurate the speed through higher sampling the better the power prediction according to the polytechnic prof that developed Insoric in Switzerland. Here is his pitch (unfortunately in german). As usual they want a suitcase full of money for the sensor.
https://www.youtube.com/watch?v=cIHmWZ1jGYo
2008 A6 BPP 267kmh also 283kmh 2003 Jetta Wagon ALH 150mph, 188BHP - 365 lbft, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old June 2nd, 2017, 12:59   #48
Layerz
Hrmm I'll need to go over this later - for ages I've been meaning to turn the this into something with my Arduino.
The lack and price of an AWD dyno's in my area makes measuring changes purely opinion based.
Thanks for the links and if you'd like my bits explaining I'll need to refresh exactly how we came to that as an engineer friend helped me with the spreadsheet. At the time I made that I was tinkering on the most shoe string of budgets and tbh even now I have things I'd rather spend money on then full VAGCOM.
Old June 4th, 2017, 09:01   #49
eddie_1
eddie_1's Avatar
Updated the Video with 0-100Kmh run. VCDS gives 7.37sec.
Bit tricky to do with FWD traction issues and manual gear changing.
DMF groans just a bit but not too bad.
Old September 19th, 2017, 15:27   #50
eddie_1
eddie_1's Avatar
Finally got around to upgrading to the BiTDI MAF. Used the BiTDI plastic tube and a 45deg elbow silicone reducer from ~78mm ~57mm. Cut the silicone reducer to get the right length. The CCV is venting through a hose at the moment, but need to couple it into the plastic BiTDI tube section. Plot included of the BiTDI MAF linearization map which is 37point while my stock BPP MAP is 57 point. Adapted the BiTDI MAF to 57 point.
Still need to try it out on the highway. Not 100% sure if this was the limitation. My IQ was being limited fairly linearly above ~4000rpm. Could be other limiters as well.
Old October 1st, 2017, 06:33   #51
eddie_1
eddie_1's Avatar
Bingo!
The fueling was indeed MAF limited at higher RPM and thankfully I did not run into further limiters. The charts show how the MAF is vastly improved at higher rpm and how the fueling is now extended.
I had issues getting the newer Biturbo MAF element to work but resolved it by using the old element in the new Biturbo housing. Details are in this thread.
Below that a pic of how I adapted the Biturbo hose to attach the CCV. I cut out the old coupler and attached it using the JB Weld epoxy.
My 3rd gear pull time improved about 30% between 4000 and 4500 rpm with same fueling. Got a bit of smoke up there now because I had pulled in the boost a bit for protection. It will be interesting to see what happens with my top speed with power up there, although the Avant doesn't have the best drag coefficient.
Old October 1st, 2017, 06:38   #52
altz1
TDI(s): Allroad, A8
Good job Edward! How much fueling you have now in 3000-4500rpm?
Audi A8 4E 4.2TDI 522hp, 1100nm. - Sold
BVN 4.2TDI, 2x gtd2060vzk. - build
MB S450CDI - dd
altz1 is offline   Reply With Quote
Old October 1st, 2017, 06:48   #53
eddie_1
eddie_1's Avatar
Hi, Thanks for your tips.
Here are the values:
2919 83,9 3129 85,1 3297 85,9 3465 85,9 3633 85,9 3780 85,9 3969 85,5 4116 85,1 4263 84,7 4410 84,3 4557 83,9 4683 82,7
With about 1.9bar on the gauge. Not sure if I want to push the Turbo much more.
Old November 23rd, 2017, 08:33   #54
eddie_1
eddie_1's Avatar
Went for a spin today after the BiTurbo MAF housing upgrade. I also extended the fueling 86 mg/str to 5000rpm and a bit above. Running 2 bar boost to about 4700rpm. THE CAR REACHED 283 KM/H speedo without too much effort, fairly quick and EGT (only 944C) was not an issue because didn't have to hang around trying to get there. Could have a gone a bit more but it was fast enough. Probably the highest top speed with this engine and transmission in an A6 C6 station wagon. Here is the video:
Hardlink:
https://www.youtube.com/watch?v=Eh2Ft7fsQrM&t=3s
Attached pic of speed. then fuel extension log. The CCV connection did not glue, so I cut a thread in the hose and it is fine now. pics attached of final setup.
Old November 23rd, 2017, 08:49   #55
altz1
TDI(s): Allroad, A8
Nice to see clean build with useful upgrades. By useful upgrades i mean that every part is installed with a reason and helps to get to the goal.
Btw, .....it ...smells like...turbo upgrade soon 300kmh is not too far anymore, but you are probably limited by gearing. Good work in general
MB S450CDI - dd
Old November 23rd, 2017, 09:07   #56
eddie_1
eddie_1's Avatar
Thanks for the encouragement and advice. Definitely something to think about with better compressor maybe. Gearing maybe still just ok to get to 300kmh. I was still under 5000rpm. But it is getting scarier with the speed.
Old November 23rd, 2017, 12:13   #57
majesty78
majesty78's Avatar
TDI(s): VW Polo ASZ
Fuel Economy: 30mpg
"EGT was only 940 degrees"
Celcius?
If so, then you "only" exceeded the limit by 100 degrees.....
Seat Leon Cupra R MK1, VW Polo 1.9TDI ASZ
majesty78 is offline   Reply With Quote
Old November 23rd, 2017, 12:25   #58
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
I know many people go well above 950 but for me 930-940 is as far as i'm gonna go.
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old November 23rd, 2017, 12:28   #59
eddie_1
eddie_1's Avatar
Celcius?
Hallo Alex, i saw several threads saying 950C is probably ok for short runs. Is 850C the spec.? I saw some descriptions a while ago, about newer Garrett and GTB2260VK having slightly better heat performance?
Old November 23rd, 2017, 12:33   #60
majesty78
majesty78's Avatar
TDI(s): VW Polo ASZ
Fuel Economy: 30mpg
Yes, 830 sustained and 850 short time is the official Garrett limitation for those GTB turbos.
Makes me wonder they could stand so much more heat, but (honey)well they seem overengineered in this case :-)
just installed new turbo and no boost vinniehobart VW MKIII-A3/B4 TDIs 2 March 8th, 2014 22:35
New turbo installed question dchapman TDI Power Enhancements 1 April 12th, 2011 05:55
Do any VW TDI's come without a turbo installed? ScottRotman TDI 101 14 October 20th, 2009 04:49
new turbo gauge installed stronzo TDI Power Enhancements 33 July 29th, 2007 14:59
Page generated in 0.21988 seconds with 13 queries
[Output: 144.18 Kb. compressed to 122.05 Kb. by saving 22.13 Kb. (15.35%)]
