temp warning light went off
draksia
Lake Mary, FL
Shortly after starting my golf(about 1 min) the temp warning went off including the beeping. The car had been sitting overnight so it was totally cold. I shut it off waiting a little then started it agian and the light never came on agian. Is this something that I have to worry about?
BGUERIN
Woodville
Same thing happened to me. The light with the thermometer picture is for the coolent level and the temp. is measured by the Temp. guage. Just add a little coolant BUT make certain you use the right one. V.W sells it by the gallon which you may never use the rest of it. If you drive stirctly in the warm south you may get away by just adding a little distilled water since your antifreeze is premixed at the factory for colder temp. You can check this with a antifreeze gauge.
Joe Golf
Vero Beach Florida
2017 Passat 1.8T
MY98 Passat does the same thing everytime it gets really cold out. Once the fluid warms slightly the light/bell goes off.
If the fluid level is OK, don't worry about it. I checked the specific gravity of the fluid and it was fine for -40f.
jmur
CT
That would happen to me on an older Golf. Just wiping some scum off the coolant level sensor fixed it.
