Mikkijayne
Hi All,
I recently swapped an 11mm pump on to my AFN and its had a catastrophic effect on the fuel consumption
I've got .216 T4 nozzles and a 2052V turbo, but the engine is otherwise stock - not chipped. The pump has transformed the car - much more grunt across the range, more driveable at low speeds, revs easily to the redline etc, spools the turbo 200rpm sooner, and actually makes less smoke than it did before (ie virtually none).
I was getting 40-42mpg with the 10mm pump, but now I'm getting 34 ish with the same driving style The computer is reporting the same as it did with the previous pump, which sort of makes sense since none of the ECU parameters have changed.
Since it now makes less smoke than before, where the hell is all my fuel going? It would make sense if I was thrashing it everywhere, but most of my journeys are freeway where I'm doing the same speed as before.
Any thoughts on what might be wrong please?
(timing is bang on according to VAG-COM btw. I didn't bother to adjust the IQ since it doesn't smoke)
