lumpy idle and lumpy 2500rpm. Occasional popcorn. Worried about cam. Logs included.
Sella Turcica
USA
none anymore
05.5 BRM with 117k miles, original cam, 505.01 every 10k or less.
There was some minimal wear on my cam at 85k miles a couple of years ago but we had no running issues so I shrugged and let it be. Fast forward to now.
At idle, when cold or warm, there is a notable occasional lumpiness, or a miss, or whatever you'd like to call it. It very lightly shakes the car. Doesn't matter if it's in park or neutral. That same lumpiness/shakiness is pronounced around 2500 rpm but the rest of the range is pretty good. Once every couple of minutes I hear the "popcorn" knocking sound others have described, which lasts a couple of seconds.
I'm pretty concerned my cam is on the way out, and I plan to lift the VC again sometime this week and check it out. I ran the VCDS tonight but I'm not sure what to make of it, so I'm copying my logs here in case some guru has an idea.
Tuesday,17,April,2012,00:12:35:60430
VCDS Version: Release 11.11.2
Data version: 20120126
Chassis Type: 1K0
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 56 62 72
7D
VIN: Mileage: 188480km/117116miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7329
Revision: --H01--- Serial number: VWZ7Z0E1717803
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 64E97E07A7409E3
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 042 H HW: 02E 927 770 AD
Component: GSG DSG 041 0905
Revision: 04004010 Serial number: 00000501200450
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 18111AF72B888A3
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021122
VCID: 3A55E07F7544B83
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AG
Component: ClimatronicPQ35 066 0505
Shop #: WSC 00000 000 00000
VCID: 6CF916274F90D63
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 C HW: 1K0 937 049 C*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000000058959
Coding: E4098E02400418000014000000140000002077035C
VCID: 2F43C12BBE066DB
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00000
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 00000
1 Fault Found:
00985 - Right Tail Light (M2)
012 - Electrical Fault in Circuit - Intermittent
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0080
Revision: 00000000 Serial number: AUZ4Z7E4036376
VCID: 2B7BD53B8A1E11B
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 176
Reset counter: 204
Mileage: 131388 km
Time Indication: 0
Date: 2000.00.00
Time: 17:02:16
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD01G5F.
Coding: 0012627
VCID: 2E7DDC2FB90C643
Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AB HW: 1K0 953 549 AB
Component: J0527 010 0045
Coding: 0010041
VCID: 72C5085F6DB4003
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 971 D
Component: KOMBIINSTRUMENT 3HL 2120
Coding: 0021203
Shop #: WSC 08305 993 56004
VCID: 2C79D6278F10163
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700105109062A
Coding: 3F3F0B620F1002
VCID: 29772F3380E203B
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 HW: 1K5 919 965
Component: Kompass 002 0001
Revision: 00002000 Serial number: 0371356TNKJZ03
VCID: F8D1BA778BC8EA3
2 Faults Found:
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 208
Mileage: 183942 km
Time Indication: 0
Date: 2000.00.00
Time: 14:34:21
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 208
Mileage: 183942 km
Time Indication: 0
Date: 2000.00.00
Time: 14:34:21
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 2120
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2339
Coding: 0001271
VCID: 364DF44F415C5C3
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.3 1502
VCID: 3041C257A338723
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 13100F880106003F2D06050FA0080F0490A540
VCID: 8225D89FDD14B03
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Component: NGS n.mounted
Component: IRUE n.mounted
2 Faults Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 27
Mileage: 147242 km
Time Indication: 0
Date: 2000.00.00
Time: 06:16:12
00930 - Locking Module for Central Locking; Rear Left (F222)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 15
Mileage: 169515 km
Time Indication: 0
Date: 2000.00.00
Time: 04:56:38
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No: 1K6 035 456
Component: 08K Audioverst. 0003
Revision: 00002000 Serial number: 00000000019904
VCID: E9F7EF33C06243B
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001271
VCID: 3753F94B4656A5B
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 HW: 1K0 035 180
Component: Radio DE2 008 0115
Revision: 00008000 Serial number: VWZ4Z7E2019594
Coding: 0010010
VCID: DD9FCBE3042A2FB
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2416
Coding: 0000144
VCID: 3147C753A8327BB
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 3245C85FAD34403
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D7FDB23B40A1FB
End ---------------------------------------------------------------------
Readiness Status: 00000000 00000111 11100000 00000000
MIL Status: MIL OFF
Comprehensive Components: Passed
Fuel System: Passed
Exhaust Gas Recirculation: Passed
Number of EOBD-related DTC(s): 0
Then I did some real-time logs with a few of the engine parameters, at different RPMs and I have posted these below.
00:06:23
840 /min Engine Speed (G28)
4.1 mg/str Injection Quantity
979.2 mbar Boost Pressure (actual)
-0.42 mg/str Injection Quantity Deviation Cyl. 1
-0.14 mg/str Injection Quantity Deviation Cyl. 2
-0.14 mg/str Injection Quantity Deviation Cyl. 3
0.75 mg/str Injection Quantity Deviation Cyl. 4
-72.0 Switch Time Deviat. Cylinder 1
-53.0 Switch Time Deviat. Cylinder 2
-52.0 Switch Time Deviat. Cylinder 3
-43.0 Switch Time Deviat. Cylinder 4
3.49 Lambda/Oxygen Sensor Value
00:07:13
1890 /min Engine Speed (G28)
1009.8 mbar Boost Pressure (actual)
-0.49 mg/str Injection Quantity Deviation Cyl. 1
-0.07 mg/str Injection Quantity Deviation Cyl. 2
-59.0 Switch Time Deviat. Cylinder 1
-64.0 Switch Time Deviat. Cylinder 2
-54.0 Switch Time Deviat. Cylinder 3
-41.0 Switch Time Deviat. Cylinder 4
3.09 Lambda/Oxygen Sensor Value
00:07:39
2625 /min Engine Speed (G28)
4.9 mg/str Injection Quantity
1040.4 mbar Boost Pressure (actual)
-37.0 Switch Time Deviat. Cylinder 1
-51.0 Switch Time Deviat. Cylinder 2
-38.0 Switch Time Deviat. Cylinder 3
-27.0 Switch Time Deviat. Cylinder 4
3.79 Lambda/Oxygen Sensor Value
00:08:08
3570 /min Engine Speed (G28)
7.7 mg/str Injection Quantity
1162.8 mbar Boost Pressure (actual)
5.08 Lambda/Oxygen Sensor Value
Sella Turcica
USA
none anymore
I'll be checking the cam soon - now I'm just wondering what setup to go with since I know there are a number of options.
