SFHGolfTDI
- Joined
- Nov 3, 2003
- Location
- Ventura, CA
- TDI
- 2002 Jolf GLS TDI - Reflex Silver (purchased 2011) | Previously: 2001 Golf GL TDI - Indigo Blue (sold 2005)
I've been in touch with a couple of our esteemed tuners and would like some input before making decision. My plan is to go with a stage 2-3 tune on all stock hardware. (I know many people recommend nozzles first, but I'd like to use mine until they're worn, but still gain some power/efficiency/fun in the meantime). When I have more money and/or need for clutch upgrade, I'll consider further mods. Car has about 112k on it with no history of any problems. I've owned it since 74k. Here are my options so far, followed by a few questions:
EDIT: Just to update this thread. I ended up going with Kerma tuning. Charlie gave me a great deal on tune + q-loader and has been helpful to work with (including answering my many questions and offering feedback on before/after logs, etc.). The convenience of having the loader and future re-tunes for upgrades was important to me.
Charlie made me a tune file that includes my stock tune + 2 tunes (3 total) that I can switch via VCDS soft coding (everything works, cruise, etc.). I can't compare to other tuners, but I love how the car drives with both tunes (one delivers a little more go). Max boost seems set around 17.5. Very smooth and the power is just there when it wasn't before, especially when passing cars, up hills, etc. I only wish I drove more than a few times a week so I could enjoy it more.
Most likely: RC2/RC3 ALH Switchable tune. RC3 tops out at about 18 or 18.5 (safe limit of VNT15), RC2 about 17/17.5 boost. I'll see what I enjoy driving more and also have the RC2 option in case I have boost spikes or clutch slip I need to sort out, or for road trips, winter trips, etc. I may even opt for switchable Stock/RC2/RC3 if I can get all three of those on my ECU with no downsides. Also, March Madness sale is coming up for 20% off, so that is a bonus. [I would have gone with an ASV tune if I had a second ECU, but don't want to hassle with that now, also emissions readiness.]
TDTuning Stage 3. About 17.5 boost. About the same as RC2, keeping stock turbo well within what is safe.
Malone Stage 1. Not really leaning towards this for the time being. The only positive might be the dynamic EGR (which I would like some input on below).
- EGR: I know traditional thinking is that EGR is "bad" b/c it sends soot back into your engine and tends to block the intake over time. Presumably, this seems to be less of an issue now with ULSD, and on top of that I use biodiesel blends which keep things cleaner. I know in colder climates, some like to keep EGR on, or at least "dynamic" EGR, to help engine get warm and stay warm, while others think there is no difference. RC prefers to just turn it off, TD keep it on, Malone has dynamic option. Living in SoCal, I do also care about air quality and my impact. What are the downsides or upsides to EGR on/off? My plan originally was to have RC3 maybe with EGR off, and RC2 with dynamic or EGR on. Note: I live in a state that tests for OBDII readiness, but I think RC tunes have no issue with that. TD wants to keep it on for that reason.
- How likely is it that I will have an overboost issue with RC3 on stock hardware? Fueling will already be limited by stock nozzles, and as far as I can tell my VNT is not sticking and previous WOT logs have not shown any issues. I have VCDS and SGII, and plan on doing a few VCDS logs once I have the tune to confirm there are no issues (and I'll install a boost valve or go to RC2 if I do).
- Lastly, I know that RC switchable tunes write the different programs to the Auto, Manual and 4-motion blocks of the ECU (?). Any known issues with that? ABS, Cruise control, etc.? I've read only that in the auto block, the clutch will not disengage CC (I usually use my brake for that anyway). Any other known issues?
