Ok. Im trying to narrow down my problems with my AC/Heat. Bear with me!
Symptoms: Low air-flow on all settings. There is a small amount of air flow but signifigantly less than what has been normal. I can hear the speed difference but the air flow that comes out is not "normal". Im going to assume this is because the motor is going bad and not the resistor pack.
I've done searches on the "resistor pack" and the jist i get from this is if the a resistor on the resistor pack is bad you either lose a speed setting? correct me if im wrong, please!
Next: I've done some searcing for the blower motor and have come across this one
http://www.autohausaz.com/search/product.aspx?sid=sif0uizxgcz2zjmroh0eyj55&makeid=800026@VW&modelid=1375556@JETTA%20TDI&year=2001&cid=24@AC%20%26%20Heat%20-%20Climate%20Control&gid=6916@Blower%20Motor
There is a note stating: This is the updated version. Modification to existing plug may be required on models prior to 2003, per Audi/VW service bulletin.
Can anyone shed some light on this?!
Thanks,
Josh
Thanks,
Josh
