D danblp Well-known member Joined Sep 13, 2015 Location blackpool TDI 1.9 tdi ahu polo estate Jun 17, 2017 #1 Stuck between pd130 passat estate and a4 avant which would be better and 5 or 6 speed?
arazvan2002 Veteran Member Joined Sep 28, 2010 Location Romania TDI Audi A4 B6 1.9TDI AVF quattro Jun 20, 2017 #2 6 speed has a stronger clutch. You can upgrade it to higher torque. Chose the AVF engine (this one has 6 speed).
D danblp Well-known member Joined Sep 13, 2015 Location blackpool TDI 1.9 tdi ahu polo estate Jun 20, 2017 #3 Should i go fwd or 4wd quattro or 4motion?
T thzpcs Well-known member Joined May 15, 2014 Location Denver, CO TDI 2008 Golf TDI Jun 21, 2017 #4 Quattro is usually a Torsen system, while 4Motion is a clutch based Haldex system. Although, I think the A4 uses a Haldex system.
D danblp Well-known member Joined Sep 13, 2015 Location blackpool TDI 1.9 tdi ahu polo estate Jun 21, 2017 #5 Best sticking to fwd?
arazvan2002 Veteran Member Joined Sep 28, 2010 Location Romania TDI Audi A4 B6 1.9TDI AVF quattro Jun 22, 2017 #6 The Passat B5 /5.5 1998-2005 uses same transmision with A4 B5/B6, with Torsen, because both have longitudinal mounted engines. You can chose quattro/4motion if you like it and fits your budget.
