LukeWilson
Time for a new project (not that I needed another one)!
I've always loved the Allroads and thought they would be the ultimate daily driver, only problem was I've dealt with enough 2.7T's to know that I would never own one and I dropped the idea. Then I met Wing_Man who was about to start his Allroad BHW swap and the idea popped back into my head. A year later and many miles covered on an R1200GS, I was going to need a winter daily driver and the search began.
Got a great deal on a 2005 Passat with a pooched transmission:
Then a month later, managed to snag a 2004 manual Allroad in decent condition for a very good price as well:
I pulled the BHW out and started to give it a little TLC. New timing belt, balance shaft delete and general cleaning up (horrendously filthy after 320k kms):
Then I got a TDI 01E from Frans at Dutch Auto Parts. I was very happy with the transaction and couldn't believe how fast it showed up (4 days!).
The next issue was finding a clutch that would hold a stage 2 tune now and probably more in the future. After much searching, I decided to go for the single mass 240mm frankenclutch recipe. Took some time to source the correct parts, but so far I think I only have $350 into it. So assuming it holds, it's by far the most cost effective option.
I'll be removing the 2.7T and existing 01E this weekend and maybe even get the BHW put back in if I can get my flywheel/pressure plate balanced in time.
I will be creating a wiring chart as I go, hopefully this will make it easier for future Allroad swappers. A lot of it is the same/very similar between the two harnesses, but there are definitely a few pins that will need to be figured out.
The general plan is to run the hottest tune I can on stock injectors and turbo for the time being. The main goal is a quick swap, good fuel economy and similar drivability to the the 2.7T.
More to come very shortly!
