Hey thanks guys; full vacuum to the wastegate = full boost in either vehicle. That's a good start. Now, how does the VNT bleed boost? In my testing, simply removing power from the solenoid does not bleed the vacuum. Like I said, it seemed like you had to pulse it.
I did get the chance to turn a wrench on it tonight. I think I have the intercooler ready to be bolted on
I'm going to have to relocate the horns as they were pulled to make room for the IC. No biggie. The factory IC piping fits almost to a 'T'. There are a couple of joints with a little stress on them that I will have to monitor. Also, the aluminum tube right off the turbo is having some clearance issues with the A/C line at the firewall. I may have to fab a new pipe from the turbo up to the plastic tubing.
Here's where the IC sits in relation to the nose of the van. There is an opening above the fog lamp, but it may not be quite sufficient. I'm thinking a small, narrow air scoop right at the lip of the air dam may be needed to flow air over the IC. Then I may have to slit the fender liner to let the air back out.
Also, I got the clutch reservoir mounted a while back, just didn't get pic's.
It's off a Yamaha R-series crotch rocket. I just needed a small little reservoir (I threatend to simply use a hose with a vent at the top!
) I harvested this off eBay new for like $10. It has a little mounting tab with a metal sleeve insert; perfect.
Later!
Travis
