Anyone tried to add a backup camera to a 2013 Passsat TDI SE w/Sunroof?
http://item.mobileweb.ebay.com/viewitem?sbk=1&nav=SEARCH&itemId=171036204250
RNS-315's have the 26-pin connectorI wonder if that port was added as a rolling model year change or just the '14 got the input. Although I do remember reading somewhere (I think it was a pre release info sheet for the NMS posted somewhere on here) that the 315 should have the port.
This is going to take some research but you "should" be able to get optical parking sensors working with the rns510k.. I have a two day old 2013 PASSAT TDI SE (Build - 03/2013) with "AF" RCD-510 Version. Part # 1K0035180AF.
So i have no option to get a backup Camera? Anyone has any idea on any other options?
Take a look at the pictures here:
http://www.bold-sport.com/store/index.php?route=product/product&keyword=ops&product_id=72
You can either install 4 sensors in the rear bumper or get 8 sensors for the front and back.
If you really have deep pockets you can get 10 sensors (6 on the front and 4 on the back), the proper controller module AND the proper abs module and have the car park itself (Park Assist).
One final thing, you might want to pull the radio and make sure the plug isn't there. Vortex guys have been retrofiting their 2012's
http://forums.vwvortex.com/showthread.php?5500210-HOW-TO-Passat-B7-Rear-View-Camera-Install
For 2013 models, unless it had the RVC stock, it cannot be added to the stock system.My parents bought a new 2013 Passat TDI, but it does not have navigation/backup camera/anything extra. It does have the nice large display screen that I assume would work quite well with the backup camera, which I would like to get installed for Christmas on their car - can someone point me in the direction of what camera they'd need? I've tried to read the threads, but I can't tell what camera would work with a unit that doesn't have navigation.
Also, this is probably out of my price range, but could a nav system and camera be installed simultaneously? Are there aftermarket nav systems?
Finally, any leads on a potential installer in the New Orleans, LA or Baton Rouge, LA area would be greatly appreciated (or Biloxi MS area as well).
