Sprocket
Sprockette's hubby
- Joined
- Nov 18, 2004
- Location
- MI
- TDI
- 2014 Jeep Grand Cherokee Summit Eco Diesel, 2005 Passat Silverstone Grey, 1996 Passat Storm Grey
A few of us have been "talking" about upgrading from an automatic trans to a 6 speed manual trans in our B5.5 Passat's for a few years. This came up again while we were at the N.A.I.A.S. GTG in Detroit this weekend. I get all warm & fuzzy whenever this topic is brought up so, I figured this would be the thread to discuss what needs to be done to accomplish this and perhaps actually do this swap instead of talking & fantasizing about it.
Oilhammer mentioned that the B5 TDI's don't have the software option to be recoded from an auto to a manual like the Jetta's do. We both said that we wouldn't want to do the swap & have the CEL lite up afterwards. I'm looking for input from tuners to see if they can provide a solution or software change to either recode the ECU or to make it not throw codes for the new manual trans.
As far as transmissions that would work with our longitudinal engines, the only one I'm aware of is the O1E that would have to be imported (TDI gearing of course). Are there other options or is this the only/best one to use? Does anyone have the R&P and gear ratio's?
Another big concern is will this trans fit with our stock sub-frame or will that need to be changed or modified? Will the exhaust need to be moved to make room?
Like other auto to manual swaps we're going to need additional parts & pieces to make this work. I don't have access to Etka to look up parts nor do I have the knowledge, skills, or tools to do the swap. So if anyone can help with part #'s, that would be great. Fortunately, there are people near me that can pull of the installation
I don't mind being the guinea pig and having this done to my car. I just don't want to buy parts & find out afterwards that it won't work or fit and be out time & $$$. I also don't want to be in that situation where I forgot to order a part that is only avail over in Europe and have my car torn apart for several weeks or months. I'd like to make a detailed list of what needs to be changed & ordered beforehand so there is minimal downtime when the swap is performed.
Is there anything else that will make this swap easier or more difficult to do vs the Jetta swaps?
