A430TDI
ReallyYou still have 80hp left with yours. 450hp should be closer to max with these stock injectors.
I have the exact same feelings, lol!I cannot describe my petty level of jealousy. That level of torque with Quattro AND a third pedal?!?!
But you also said:http://forums.tdiclub.com/showthread.php?t=429110
Your ASB is running out of the pump and not injectors. Downgrading to older CP3 pump found on BMK egines will give you bit more flow. Still with stock fuel lines and lift pump.
You are running out of turbo tough.
So is it just the pump or also nozzles?The nozzles are just too small. 1ms duration would be much better for power production at high revs compared to current situation.
I'd like some of that but have no idea how to get there.How much do you want. 430hp on stock nozzles is already done. With more air there would have been even more. The stock nozzles are within few precent of what BMW E60 535D nozzles are.
