OllieBrown
My 04 Beetle PD TDI won't start. I went through the troubleshooting here and have discovered that the in-tank fuel pump is not working (no whirring sound, disconnected the fuel filter intake line and with key in on position nothing came out). I put a voltmeter on the plug going into the pump and I get nothing when I turn the key to on so it seems power is not getting to the pump.
I've tried the obvious things:
- The so-called relay J17 (it's a 53 in position 10 on my beetle) is clicking as the key goes to on. I can also measure a voltage across the relay terminals after I turn key to on that goes away after about 4 seconds.
- Fuse #28 is good (tested with the multi-meter just to be sure).
- Relay 109 seems to be fine. It was already the gray one and my glow-plug light comes on like normal.
So, I'm looking for other ideas. Should I be suspicious of the wiring at this point? What on earth could have caused it to go bad. Is there anything else between the pump connector and power (other fuses, other relays I should suspect)?
Thanks!
Seth
Thanks!
Seth
