TDIsyncro said:
Well, this thread made it all away back to page 6. lol Time for a project update.
I too have been loaded up with work in the past week or so and haven’t even communicated with Louis very often during this period as has been usual. I will try to address the last few recent posts here.
Cams:
My cams are sitting at Colt Cams and he will be looking at the OEM grind and our options over the next two weeks. It has recently been brought to my attention that some of the lobes on the CBEA have actually spun causing engine damage. If you look back at the cam picks, you will see that they are hardened steel lobes on a tube steel core. We are considering some options for securing the lobes to the tube. In the end, I will be going to a custom billet cam set, but for now, we need to make the regrind work.
Pistons:
need valve and cam feed back to spec fly cut size and depth. I am currently looking at some custom billet pistons that would incorporate some interesting design features. There would be no reinforced upper ring groove, so that is the one main negative trade off.
I need stock cam specs to be able to go from there in my calculations and simulations.
I have been making some slow progress on the girdle design. Just getting hole locations and some of the machining tolerance dims refined.
One of the steps was checking the bolt pattern with full scale paper template bolted to the block through the bolt holes for the mains, and pinning with the four corner oil pan bolt holes. The red circles indicate where additional holes are beng added to engage the BS rib holes and the two M9 holes at the rear of the block.
M9 threads seem extremely unorthodox for VAG and general engineering practise. Are you sure about this?
One of the Chalanges with this design is to make it deep enough to clear the rods at BDC.
I see what you’re saying, we’ll discuss this.
GoFaster said:
Ho-ly smokes. I can't believe that I never read this thread until now. What an awesome project. Tdimeister and I were on the same wavelength of keeping cylinder pressure under control years ago, and we've spoken about compound turbos before, but that was before he left for Germany and obviously he's gained a ton of experience (and access to proper simulation software) since then. I never imagined it would lead this far, though!
Yes Brian, I’ve been back for over a month and we still haven’t gotten in contact. Please send me an e-mail with your phone number again. I look forward to catching up again.
shizzler said:
Make sure to give this lots of thought before you commit to a cooling nozzle alteration strategy.
Adding a second nozzle might seem like an easy improvement.... until you consider the flow of oil through the piston. It is designed to flow in one side, splash throughout and then exit the other side. If you force oil into both sides of the piston there is the potential for a partial stagnation of oil flow within the cooling gallery. If you get burnt / coked oil within the gallery then you are effectively adding insulation from the piston, too, further hindering heat transfer. Your best bet would be to simply get more oil in (enlarge / bump pressure of current squirter) and then let more oil out of the piston. Pistons with cooling gallerys are usually NOT full, maybe 50% at best. One major reason for this is that the oil jet stream is not engaged with the gallery entrance hole at all parts of the stroke. Sometimes this is the goal though, to splash the rest of the undercrown and hit the pin joint. I am not familiar with the TDI design goal, but it looks like the nozzles basically point straight up, so that's good. Furthermore the stream is often slower than the piston moves up in the bore at higher rpm, so it only fills on the downstroke. Adding a supplemental oil drain hole that would drip/splash over the wrist pin joint would be a good idea, too. You can never have too much oil on the wrist pin / pin bores of the piston.
I'm also nervous about your "billet" pistons. I don't recall if you mentioned the material. Steel or aluminum? Aluminum without a reinforced top ring groove will NOT survive long at full load. You'll get a lot of top ring pound out, micro-welding in the groove, etc. Eventually oil consumption and blow-by will suffer with even bore scuffing possible, or piston failure. At the very least look into getting the entire top of the piston (or at least the top ring groove) anodized.
What is the nature of the machined in cooling passage also? How is that even possible on a billet piston?
In any case, when you do finally get this beast running and up to full power, I would suggest bore-scoping your cylinders OFTEN. Signs of piston crown melting should be pretty obvious, but also might happen too fast to catch.
I agree with Shizzler. There are two holes in the OEM piston that lead into the cast-in annular oil cooling channel. One is for oil entry and the other for exit. If you spray oil into both simultaneously you will not allow the proper flow and likely make the thermal problem worse. A solution integrating 2 squirters might be to drill
2 holes and by appropriate plugging, each squirter would effectively serve one half of the piston. But if one squirter fails…….. I also don’t like the idea of drilling holes into the piston and plugging with material that will go up-and-down up to 6000 times a minute under huge thermal and mechanical loads.
Increasing the flow and velocity of the existing squirters and furthermore spraying oil from a cooler source seems to be a more attractive solution. I have not investigated it yet, but I suspect that modding the oil galleries to spray oil from a different source will prove easier said than done, requiring serious modifications to the oil galleries and being akin to doing a coronary bypass…
Keep also in mind that increasing flow rates and pressures in the lube system is nice to toss around, but doesn’t come for free. I don’t want a system that will take 20 HP just to drive! We need to think about our technical needs and solve them with the minimum expenditure of power, cost, complexity and risk.
The billet aluminum piston option is tdisyncro’s own initiative; I’m focusing on the turbocharging, cam and manifold development. We have been and will continue to discuss other project issues, but the pistons is his area of responsibility, just as each individual contributing in this project has his own respective primary responsibilities. Being billet, there are no provisions for an oil cooling channel, integrated expansion inserts or for top-ring reinforcement. The oil spray will simply hit the underside of the pistons, so it doesn’t really matter how the squirters are laid-out.
