Ross-Tech to the rescue
So the VAG-COM arrived Monday; downloaded software Tuesday; successfully connected to Cruise Control "Group 6" today, afetr re-reading post by Wingnut on flaky CC.
My screen is quite a bit different, which is to be expected, I suppose (newer version?)- but I was sorely disappointed in the rather expensive Bentley manual I bought. It clearly states "Including PD versions" on the cover, but goes no further than the 2002 ALH diesels in both the wiring diagrams and the scan tool section. Hopefully, not too much has changed.
Long & short: all switches changed the 8-digit (not 6-digit any longer, apparently) codes in the "Pedal Monitor" and "Switch Monitoring" sections, except one: The Clutch Switch.
Pushing in the clutch made no changes in ANY of the group 6 blocks. Ah, progress at last! All others did- accelerator pedal, brake pedal, Cruise ON/OFF switch, SET, and RESUME all made changes to the codes (% reading on the accelerator pedal), but not the clutch switch.
Question: the starter interlock works-- i.e., the starter won't engage until the clutch is depressed-- so that part appears to be working; anybody know if that's on separate circuit/switch from the CC's "vacuum vent valve" switch (F36), as it's called in the Bentley book? My assumption was, since the starter interlock worked, the clutch switch was OK-- but perhaps that's a different circuit altogether? (I'll dig through the Bentley book later.)
Yeah, I know-- "assume": makes an a__ out of u and me.... Anybody with BEW experience out there who could save me some time?
Never mind.... Just re-read THIS post from beginning; thanks, jcrews! "Use VCDS to check the clutch vacuum vent valve F36 sensor. Measuring block 006. There are two switches on the pedal. One for the starter, and the other for the ECM. The lower one should be the F36 switch."
