Does CARB apply to pickup trucks? Around here F-250 diesels, etc seem pretty common, and trucks in general are very common. I just haven't read or heard any advertisement for clean diesel trucks. Just curious. I live in a non-CARB state .
Hi TR,TornadoRed said:Every new president that comes into office revokes a great many executive orders promulgated by his predecessor. In 2007 President Bush signed Executive Order 13422 calling for improved cost-benefit analysis in environmental regulation and ensuring new regulations by agencies could be vetted in the White House before they took effect. While EPA was not mentioned in the EO, it was widely known that the EPA had gone out of control and 13422 was intended to bring it back under executive control.
In President Obama's first week in office in January 2009, one of his first actions was to revoke 13422 -- letting the EPA have its independence back, to do whatever it wants. Of course it will do what Obama wants it to do -- regulate every aspect of daily life by businesses and households. But Obama does not have to take the blame for what it does, he can pretend that the agency is independent of the White House.
Does this mean that they are and have been manufactured to the same standard as the new clean TDI Jetta and Golf standards ? Or do they get off with a lesser standard ? I knew they had particulate filters as do many of the European diesel cars, but I didn't think that they had the extra stuff that a car needs to be sold in a CARB state.Bob_Fout said:All diesels 2007 and newer are "clean diesels". Your 2007 and later medium and heavy duty trucks have DPFs (hence the need for CJ-4 oils and ULSD in them).
They meet the lesser Federal EPA standards. Don't know how that compares to CARB states.Marley said:Does this mean that they are and have been manufactured to the same standard as the new clean TDI Jetta and Golf standards ? Or do they get off with a lesser standard ? I knew they had particulate filters as do many of the European diesel cars, but I didn't think that they had the extra stuff that a car needs to be sold in a CARB state.
The bigger question, when the new regs take effect -- is how anyone can sell an old work truck? (or farm tractor, or earth mover, or irrigation pump)Bob_Fout said:They meet the lesser Federal EPA standards. Don't know how that compares to CARB states.
How does anyone in a CARB state buy a new work truck?
I thought the interior space was identical, and only the trunk space was different. And that the seats were the same or nearly so, so the comfort should be about the same.dubStrom said:What was really crazy was that for about $1000 more, the Jetta has practically the same tailpipe emissions and drivetrain, with much more space and comfort.
More objective? Interior space did seem a little more narrow. No, I didn't say the Golf is more spartan. I noted more space and comfort in the Jetta. The comfort is a combination of more weight and space. The added weight smoothes out the ride, and space is always useful.TornadoRed said:I thought the interior space was identical, and only the trunk space was different. And that the seats were the same or nearly so, so the comfort should be about the same.
You complain because the Mk6 Golf if not spartan enough, but I think you are mistaken if you think the Golf is more spartan than the Jetta. Maybe you should reexamine your criteria and try to be more objective.
dubStrom said:Do you remember the television add where the guy calculates his cost on a 65 or 68 Beetle, and they do a bit where he does his midnight ride spreading the news..."three pennies a mile, three pennies a mile!" ???
Most likely it was the placebo effect, because they're really the same size in the passenger compartment. Actually, the roofline of the Jetta is an inch lower than the Golf. The side bolsters on the Golf's seats may make it feel more confining, though.dubStrom said:I noted more space and comfort in the Jetta.
At $2.80/gallon and 40mpg, that works out to "seven pennies a mile." I'm sure that's less than the '60's "three pennies a mile", when you figure in inflation.dubStrom said:Do you remember the television add where the guy calculates his cost on a 65 or 68 Beetle, and they do a bit where he does his midnight ride spreading the news..."three pennies a mile, three pennies a mile!" ???
frugality said:At $2.80/gallon and 40mpg, that works out to "seven pennies a mile."
Some of us do not even know what Opti-Lube is, and have certainly never purchased anything like that.Derrel H Green said:More than $.07 per mile when you figure in the cost of adding Opti-Lube!
How much in additional cents per mile when doing that?
Don't leave home without it, or at least I would not if I had one.
IP wear is still a valid concern for older TDIs. The Spicer report is years old, most of us here at least saw it.Derrel H Green said:
Can't believe that you of all people do not know what Opti-Lube is.
Of course, those of you with the older models do not have
the need for it, but the newer '09s and later do IMHO.
You do read 'Horror Stories' don't you?
Bob_Fout said:IP wear is still a valid concern for older TDIs.
The Spicer report is years old [and] most of us here at least saw it.
No disrespect taken. I reference its age only to show opti-lube is not unknown on here, been semi-popular since it came out.Derrel H Green said:
I meant no disrespect for anyone with the older VW diesels.
I had a JSW in 2002 and it was indeed a fine running machine.
Wish I'd not traded it in on that used E-300DT sedan.
IMHO, I cannot see how I'd have a new TDI without using a good additive.
Just because that report is indeed old does not mean it is out-of-date and not worth considering.
That report is what I am basing my opinion on.
dubStrom said:I noted more space and comfort in the Jetta. The comfort is a combination of more weight and space. The added weight smoothes out the ride, and space is always useful.
Neither car could be consider a sports car (both too heavy).
Thank you. I didn't even really know what to research based on the previous snarky comments.TornadoRed said:Lordscarlet, the Spicer test showed that some additives are better than others at improving the lubricity of untreated diesel. The highest ranked product, however, was a 2% blend of biodiesel.
Lubricity is just one measure of a diesel fuel additive -- others include cetane boost, water dispersion or emulsification, injector cleaning, antigelling, and so on.
It may be a good idea to add something to your fuel. I do, and it may have contributed to the longevity of my injection pump. It may also be a good idea to do some of your own research and decide what is the most cost-effective way to obtain the benefits you desire. Take note, however -- not every claim made by additive producers is verifiable. Cetane boost? you can feel the difference. But better fuel mileage? that's a function of the energy in the fuel, measured in BTUs, and no additive can change the fundamental chemistry of the fuel.
