xbangu
Hello-
Have anyone have this problem before, presently everything on my steering wheel are not working. No horn, cruise won't lock in (able to turn on from the blinker rod) and no volume/track for stereo.
I have check the fuse and it's good and the connection inside the steering wheel and it's also good.
Where should I start checking or measuring voltages at next?
also, my engine check is on- don't know what's for and only have driver airbag-don't know if missing the pass side prevent it from using the the steering wheel control or the ECU need to be reset or something.
thanks,
thanks,
