can someone hook me with the 1.8T manual ECU OEM numbers
or at least what ecu shuld i look 4
i googled it and had no luck
The Part No for the Manual ECU that I picked up is : 06A 906 032 SK
Can you do an Auto Scan with your VCDS? I'm curious to see what the P/N or your ECU is... the ECU portion from my original looked like this:
Address 01: Engine Labels: 06A-906-032-AWP.lbl
Part No: 06A 906 032 LQ
Component: 1.8L R4/5VT G 0007
Coding: 07550
Shop #: WSC 06479
---VIN EDITED OUT----
1 Fault Found:
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 35-00 - -
Readiness: 0110 1101
I'm thinking that since you have a 1.8T and also had the 09a tiptronic transmission, that you are in the same boat as I was/am.
your ECU will not be recoadable. That being the case, your best bet would be to go to a junkyard and get a matching ECU and Instrument cluster. (preferable with at least 1 matching key)
At this point, you swap the matching ECU and Cluster into your car. You'll likely need to get some new Keys. Buy theses online for cheap. Take the already cut key blade from your existing keys and switch them over to the new unprogrammed keys. throw away the uncut key blade. you VW dealer WILL NOT cut them as they are usually made of a harder metal then the genuine VW keys and damage their cutting bits.
Use VCDS to program the now new keys toy your cluster. You now have a working setup with hopefully no errors. (plus your cluster no longer had that nasty PNDR cutout...)
NOW...the problem at this point... If you do an auto scan on your car, you will notice that the replaced ECU and Cluster have the VIN of the donor car. that could possibly be a problem come state inspection/ emissions time (mostly emissions) or it can just be a problem if the donor car somewhere/somehow turns up as stolen.....
To remedy this, you will need to play some musical control Moduals...
First and foremost, you will need to know or find the 4 digit PIN for both your original ECU/Instrument Cluster as well as the Donor.
Don't know/have this? Get a Vag-Tacho (as much as I don't condone it, you can get a ripoff version for cheap searching Google)
Or if you want to dish out the big bucks, the real guys are here:
http://www.vagdashcom.de/html/download.html (or at least their direct competitor)
you can use the Vag Tacho to read the PIN from each of the instrument clusters. I would not advise playing with any of the write functions as you can really mess something up if you don't know what you are doing...
The PINs should be the same for the Instrument Cluster and its matched ECU. Once you have this, the process would go something like this:
1. With Stock ECU connected, install the replacement cluster
2. Use VCDS to install the 'new' cluster to the Stock ECU.
2a. This will write your correct VIN into the used ECU
3. Install the replacement ECU leaving the replacement Cluster installed.
4. Use VCDS to 'marry' the cluster to the ECU
4a.
http://wiki.ross-tech.com/wiki/index.php/Immobilizer_III_ECU_Swapping
If all was done correctly, your stock keys should actually work here now with the new ECU and Cluster
run a recode on your Gatway. Leave it to the same value its at (should be 00006??), we just want to refresh everything. Do a throttle body alignment, and you should be done.
Sorry, but I was not able to find the exact procedure to do step 2. I know is out there somewhere, but its been over a year since I've read through it.. Its similar to process in step 4/4a but in reverse. I'll see if I can track it down later.
..Ok, fire away with the questions. That was 3 months worth of experimenting and playing condensed into a few paragraphs... I'm sure its confusing...
